Convert Raster Function Template (Data Management Tools)
Summary
Converts a raster function template between formats (rft.xml, json, and binary).
Usage
  • Raster function templates can be stored in XML, JSON, or binary format.
  • Since some formats work better on the web, you can convert your raster function template between formats. For example, you may want to convert your rft.xml function template to JSON so that you can use the template in an image service REST API.
Parameters
Label Explanation Data type
Input Raster Function Template
The input raster function template file. The input template file can be XML, JSON, or binary format.
File; String
Output Raster Function Template File
The output raster function template file path and file name.
File
Format
(Optional)
The output function template file format.
  • XML—XML output format.
  • JSON—JSON output format. This is the default.
  • Binary—Binary output format.
String
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
