Convert Temporal Field (Data Management Tools)
Summary
Transfers temporal values stored in a field to another field. The tool can be used to convert between field types (text, numeric, or datetime fields) or to convert the values to a different format such as dd/MM/yy HH:mm:ss to yyyy-MM-dd.
Usage
Caution:
This tool modifies the input data. See Tools that modify or update the input data for more information and strategies to avoid undesired data changes.
  • If the input time field is a text or numeric field, choose or specify the appropriate format for the Input Format parameter.
    Learn more about supported time field formats
  • If the Input Field parameter value is a text field, custom formats can be added to the Input Format parameter.
    For text fields that are compliant with ISO-8601 formatting, use yyyy-MM-ddTHH:mm:ss.s as the input format. This format can handle inputs that use either a UTC designator (Z) or UTC offsets (±hh:mm).
    Learn more about converting string time values to date format
  • Outputs to a text field with yyyy-MM-ddTHH:mm:ss.s format do not support the addition of a UTC (Z) or UTC offset (±hh:mm) designator.
  • If the Time Zone environment is specified, the environment value's for the Time Zone Offset parameter will be used by default, unless the parameter value is also specified.
  • If the Input Field parameter value is a Date field and the Output Field Type parameter value is Timestamp offset, you can specify the String type for the Time Zone Offset parameter and choose a time zone that will be uniformly applied to all rows in the output. For example, selecting Pacific Standard Time as an offset for an input date field with a value 2002-08-20 12:00:00 PM will produce an output value of 2002-08-20 12:00:00 PM -08:00. All other rows in the input Date field will also have the -08:00 offset applied.
    Alternatively, specify the Field type, and select a field containing the time zone offset data. Field values can be numeric, such as -5, or string, such as Eastern Standard Time. See the Time Zone Offset parameter for a list of all time zones supported as string values. When a field is specified, the tool will use the row value as the offset value. Using a field for the offset can be useful when the date values for the input rows are from different time zones. For example, if the input Date field contains the values 2001-01-01 7:00:00 AM, 2001-01-02, 9:00:00 AM, and 2001-01-02 12:00:00 PM, and the offset field contains the values -8, -5, and 0 for the corresponding rows, the tool will output the values 2001-01-01 7:00:00 AM -08:00, 2001-01-02 9:00:00 AM -05:00, and 2001-01-02 12:00:00 PM +00:00.
    The tool will not perform any time or date conversion when the Input Field parameter value is a Date field and the Output Field Type parameter value is Timestamp offset. If a time or date conversion needs to occur, use the Convert Time Zone tool to convert the date field to the appropriate date and time before using this tool to apply the corresponding timestamp offset value.
  • If the Input Field parameter value is a Timestamp Offset field and the Output Field Type parameter value is a Date, Date Only, or Time Only field, the tool will perform the appropriate time and date conversion to the specified Time Zone Offset parameter value. For example, a Timestamp Offset field value of 2011-06-02 4:30:00.000 PM -08:00 converted to Date type, with the Time Zone Offset parameter set to the String type and a value of UTC will have an output value of 2011-06-03 12:30:00 AM.
  • The Output Format parameter can be specified as Time only, but Time Only is not an accepted Input Format parameter value. This is because the Time only output format lacks sufficient information to be converted to other formats such as Timestamp Offset, Date, or Date Only.
Parameters
Label Explanation Data type
Input Table
The layer or table that contains the field containing the time values that will be converted.
Table View
Input Field
The field containing the time values. The field can be of type short, long, float, double, text, date, timestamp offset, or date only.
Field
Input Format
(Optional)
The format of the time values in the Input Field parameter value. You can choose a standard time format from the drop-down list or specify a custom format. The parameter is not supported when the input time field is of type date.
The format strings are case sensitive.
  • If the data type of the time field is date, date only, or timestamp offset, no time format is required.
  • If the data type of the time field is numeric (short, long, float, double, or big integer), a list of standard numeric time formats is provided in the drop-down list.
  • If the data type of the time field is string, a list of standard string time formats is provided in the drop-down list. For string fields, you can also specify a custom time format. For example, the time values may have been stored in a string field in one of the standard formats such as yyyy/MM/dd HH:mm:ss or in a custom format such as dd/MM/yyyy HH:mm:ss. For the custom format, you can also specify the a.m. or p.m. designator.
  • For ISO-8601 compliant strings, use yyyy-MM-ddTHH:mm:ss.s as the input format. This input selection can handle inputs that use either a UTC designator (Z) or UTC offsets (±hh:mm).
  • Commonly used formats are listed below:
    • yyyy—Year represented by four digits
    • MM—Month as digits with leading zero for single-digit months
    • MMM—Month as a three-letter abbreviation
    • dd—Day of month as digits with leading zero for single-digit days
    • ddd—Day of week as a three-letter abbreviation
    • hh—Hours with leading zero for single-digit hours and a 12-hour clock
    • HH—Hours with leading zero for single-digit hours and a 24-hour clock
    • mm—Minutes with leading zero for single-digit minutes
    • ss—Seconds with leading zero for single-digit seconds
    • t—One character time marker string, such as A or P
    • tt—Multicharacter time marker string, such as AM or PM
    • unix_us—UNIX time in microseconds
    • unix_ms—UNIX time in milliseconds
    • unix_s—UNIX time in seconds
    • unix_hex—UNIX time in hexadecimal
String
Output Field Name
The name of the field to be added in which the converted time values will be stored.
String
Output Field Type
(Optional)
Specifies the field type of the output time field.
  • Date—The field type will be date. Date fields support date and time values.
  • Date only—The field type will be date only. Date only fields support date values with no time values.
  • Time only—The field type will be time only. Time only fields support time values with no date values.
  • Timestamp offset—The field type will be timestamp offset. Timestamp offset fields support a date, time, and offset from a UTC value.
  • Text—The field type will be text. Text fields support a string of characters.
  • Long (32-bit integer)—The field type will be long. Long fields support whole numbers between -2,147,483,648 and 2,147,483,647.
  • Short (16-bit integer)—The field type will be short. Short fields support whole numbers between -32,768 and 32,767.
  • Double (64-bit floating point)—The field type will be double. Double fields support fractional numbers between -2.2E308 and 1.8E308.
  • Float (32-bit floating point)—The field type will be float. Float fields support fractional numbers between -3.4E38 and 1.2E38.
  • Big integer (64-bit integer)—The field type will be big integer. Big integer fields support whole numbers between -(253) and 253.
String
Output Format
(Optional)
The format of the output time values. Supported output time formats depend on the Output Field Type parameter value. A custom format can also be used to convert the value to a different format or to extract a portion of the value (such as the year). For a list of custom formats, see the Input Format parameter explanation. This parameter is not used when the Output Field Type parameter value is Date.
If the data type of the output time field isn't long enough to store the converted time value, the output value will be truncated.
String
Time Zone Offset
(Optional)
The time zone or field containing a numeric offset from the input table that will be used as the output time zone.
If the Time Zone environment is specified, the tool will use the that environment value by default.
  • UTC—The time zone will be UTC.
  • Dateline Standard Time—The time zone will be Dateline Standard Time (UTC-12:00).
  • UTC-11—The time zone will be UTC-11 (UTC-11:00).
  • Aleutian Standard Time—The time zone will be Aleutian Standard Time (UTC-10:00).
  • Hawaiian Standard Time—The time zone will be Hawaiian Standard Time (UTC-10:00).
  • Marquesas Standard Time—The time zone will be Marquesas Standard Time (UTC-09:30).
  • Alaskan Standard Time—The time zone will be Alaskan Standard Time (UTC-09:00).
  • UTC-09—The time zone will be UTC-09 (UTC-09:00).
  • Pacific Standard Time (Mexico)—The time zone will be Pacific Standard Time (Mexico) (UTC-08:00).
  • UTC-08—The time zone will be UTC-08 (UTC-08:00).
  • Pacific Standard Time—The time zone will be Pacific Standard Time (UTC-08:00).
  • US Mountain Standard Time—The time zone will be US Mountain Standard Time (UTC-07:00).
  • Mountain Standard Time (Mexico)—The time zone will be Mountain Standard Time (Mexico) (UTC-07:00).
  • Mountain Standard Time—The time zone will be Mountain Standard Time (UTC-07:00).
  • Yukon Standard Time—The time zone will be Yukon Standard Time (UTC-07:00).
  • Central America Standard Time—The time zone will be Central America Standard Time (UTC-06:00).
  • Central Standard Time—The time zone will be Central Standard Time (UTC-06:00).
  • Easter Island Standard Time—The time zone will be Easter Island Standard Time (UTC-06:00).
  • Central Standard Time (Mexico)—The time zone will be Central Standard Time (Mexico) (UTC-06:00).
  • Canada Central Standard Time—The time zone will be Canada Central Standard Time (UTC-06:00).
  • SA Pacific Standard Time—The time zone will be SA Pacific Standard Time (UTC-05:00).
  • Eastern Standard Time (Mexico)—The time zone will be Eastern Standard Time (Mexico) (UTC-05:00).
  • Eastern Standard Time—The time zone will be Eastern Standard Time (UTC-05:00).
  • Haiti Standard Time—The time zone will be Haiti Standard Time (UTC-05:00).
  • Cuba Standard Time—The time zone will be Cuba Standard Time (UTC-05:00).
  • US Eastern Standard Time—The time zone will be US Eastern Standard Time (UTC-05:00).
  • Turks And Caicos Standard Time—The time zone will be Turks And Caicos Standard Time (UTC-04:00).
  • Paraguay Standard Time—The time zone will be Paraguay Standard Time (UTC-04:00).
  • Atlantic Standard Time—The time zone will be Atlantic Standard Time (UTC-04:00).
  • Venezuela Standard Time—The time zone will be Venezuela Standard Time (UTC-04:00).
  • Central Brazilian Standard Time—The time zone will be Central Brazilian Standard Time (UTC-04:00).
  • SA Western Standard Time—The time zone will be SA Western Standard Time (UTC-04:00).
  • Pacific SA Standard Time—The time zone will be Pacific SA Standard Time (UTC-04:00).
  • Newfoundland Standard Time—The time zone will be Newfoundland Standard Time (UTC-03:30).
  • Tocantins Standard Time—The time zone will be Tocantins Standard Time (UTC-03:00).
  • E. South America Standard Time—The time zone will be E. South America Standard Time (UTC-03:00).
  • SA Eastern Standard Time—The time zone will be SA Eastern Standard Time (UTC-03:00).
  • Argentina Standard Time—The time zone will be Argentina Standard Time (UTC-03:00).
  • Greenland Standard Time—The time zone will be Greenland Standard Time (UTC-03:00).
  • Montevideo Standard Time—The time zone will be Montevideo Standard Time (UTC-03:00).
  • Magallanes Standard Time—The time zone will be Magallanes Standard Time (UTC-03:00).
  • Saint Pierre Standard Time—The time zone will be Saint Pierre Standard Time (UTC-03:00).
  • Bahia Standard Time—The time zone will be Bahia Standard Time (UTC-03:00).
  • UTC-02—The time zone will be UTC-02 (UTC-02:00).
  • Mid-Atlantic Standard Time—The time zone will be Mid-Atlantic Standard Time (UTC-02:00).
  • Azores Standard Time—The time zone will be Azores Standard Time (UTC-01:00).
  • Cape Verde Standard Time—The time zone will be Cape Verde Standard Time (UTC-01:00).
  • GMT Standard Time—The time zone will be GMT Standard Time (UTC+00:00).
  • Greenwich Standard Time—The time zone will be Greenwich Standard Time (UTC+00:00).
  • Sao Tome Standard Time—The time zone will be Sao Tome Standard Time (UTC+00:00).
  • Morocco Standard Time—The time zone will be Morocco Standard Time (UTC+00:00).
  • W. Europe Standard Time—The time zone will be W. Europe Standard Time (UTC+01:00).
  • Central Europe Standard Time—The time zone will be Central Europe Standard Time (UTC+01:00).
  • Romance Standard Time—The time zone will be Romance Standard Time (UTC+01:00).
  • Central European Standard Time—The time zone will be Central European Standard Time (UTC+01:00).
  • W. Central Africa Standard Time—The time zone will be W. Central Africa Standard Time (UTC+01:00).
  • Jordan Standard Time—The time zone will be Jordan Standard Time (UTC+02:00).
  • GTB Standard Time—The time zone will be GTB Standard Time (UTC+02:00).
  • Middle East Standard Time—The time zone will be Middle East Standard Time (UTC+02:00).
  • Egypt Standard Time—The time zone will be Egypt Standard Time (UTC+02:00).
  • E. Europe Standard Time—The time zone will be E. Europe Standard Time (UTC+02:00).
  • Syria Standard Time—The time zone will be Syria Standard Time (UTC+02:00).
  • West Bank Standard Time—The time zone will be West Bank Standard Time (UTC+02:00).
  • South Africa Standard Time—The time zone will be South Africa Standard Time (UTC+02:00).
  • FLE Standard Time—The time zone will be FLE Standard Time (UTC+02:00).
  • Israel Standard Time—The time zone will be Israel Standard (UTC+02:00).
  • South Sudan Standard Time—The time zone will be South Sudan Standard Time (UTC+02:00).
  • Kaliningrad Standard Time—The time zone will be Kaliningrad Standard Time (UTC+02:00).
  • Sudan Standard Time—The time zone will be Sudan Standard Time (UTC+02:00).
  • Libya Standard Time—The time zone will be Libya Standard Time (UTC+02:00).
  • Namibia Standard Time—The time zone will be Namibia Standard Time (UTC+02:00).
  • Arabic Standard Time—The time zone will be Arabic Standard Time (UTC+03:00).
  • Turkey Standard Time—The time zone will be Turkey Standard Time (UTC+03:00).
  • Arab Standard Time—The time zone will be Arab Standard Time (UTC+03:00).
  • Belarus Standard Time—The time zone will be Belarus Standard Time (UTC+03:00).
  • Russian Standard Time—The time zone will be Russian Standard Time (UTC+03:00).
  • E. Africa Standard Time—The time zone will be E. Africa Standard Time (UTC+03:00).
  • Volgograd Standard Time—The time zone will be Volgograd Standard Time (UTC+03:00).
  • Iran Standard Time—The time zone will be Iran Standard Time (UTC+03:30).
  • Arabian Standard Time—The time zone will be Arabian Standard Time (UTC+04:00).
  • Astrakhan Standard Time—The time zone will be Astrakhan Standard Time (UTC+04:00).
  • Azerbaijan Standard Time—The time zone will be Azerbaijan Standard Time (UTC+04:00).
  • Russia Time Zone 3—The time zone will be Russia Time Zone 3 (UTC+04:00).
  • Mauritius Standard Time—The time zone will be Mauritius Standard Time (UTC+04:00).
  • Saratov Standard Time—The time zone will be Saratov Standard Time (UTC+04:00).
  • Georgian Standard Time—The time zone will be Georgian Standard Time (UTC+04:00).
  • Caucasus Standard Time—The time zone will be Caucasus Standard Time (UTC+04:00).
  • Afghanistan Standard Time—The time zone will be Afghanistan Standard Time (UTC+04:30).
  • West Asia Standard Time—The time zone will be West Asia Standard Time (UTC+05:00).
  • Ekaterinburg Standard Time—The time zone will be Ekaterinburg Standard Time (UTC+05:00).
  • Pakistan Standard Time—The time zone will be Pakistan Standard Time (UTC+05:00).
  • Qyzylorda Standard Time—The time zone will be Qyzylorda Standard Time (UTC+05:00).
  • India Standard Time—The time zone will be India Standard Time (UTC+05:30).
  • Sri Lanka Standard Time—The time zone will be Sri Lanka Standard Time (UTC+05:30).
  • Nepal Standard Time—The time zone will be Nepal Standard Time (UTC+05:45).
  • Central Asia Standard Time—The time zone will be Central Asia Standard Time (UTC+06:00).
  • Bangladesh Standard Time—The time zone will be Bangladesh Standard Time (UTC+06:00).
  • Omsk Standard Time—The time zone will be Omsk Standard Time (UTC+06:00).
  • Myanmar Standard Time—The time zone will be Myanmar Standard Time (UTC+06:30).
  • SE Asia Standard Time—The time zone will be SE Asia Standard Time (UTC+07:00).
  • Altai Standard Time—The time zone will be Altai Standard Time (UTC+07:00).
  • W. Mongolia Standard Time—The time zone will be W. Mongolia Standard Time (UTC+07:00).
  • North Asia Standard Time—The time zone will be North Asia Standard Time (UTC+07:00).
  • N. Central Asia Standard Time—The time zone will be N. Central Asia Standard Time (UTC+07:00).
  • Tomsk Standard Time—The time zone will be Tomsk Standard Time (UTC+07:00).
  • China Standard Time—The time zone will be China Standard Time (UTC+08:00).
  • North Asia East Standard Time—The time zone will be North Asia East Standard Time (UTC+08:00).
  • Singapore Standard Time—The time zone will be Singapore Standard Time (UTC+08:00).
  • W. Australia Standard Time—The time zone will be W. Australia Standard Time (UTC+08:00).
  • Taipei Standard Time—The time zone will be Taipei Standard Time (UTC+08:00).
  • Ulaanbaatar Standard Time—The time zone will be Ulaanbaatar Standard Time (UTC+08:00).
  • Aus Central W. Standard Time—The time zone will be Aus Central W. Standard Time (UTC+08:45).
  • Transbaikal Standard Time—The time zone will be Transbaikal Standard Time (UTC+09:00).
  • Tokyo Standard Time—The time zone will be Tokyo Standard Time (UTC+09:00).
  • North Korea Standard Time—The time zone will be North Korea Standard Time (UTC+09:00).
  • Korea Standard Time—The time zone will be Korea Standard Time (UTC+09:00).
  • Yakutsk Standard Time—The time zone will be Yakutsk Standard Time (UTC+09:00).
  • Cen. Australia Standard Time—The time zone will be Cen. Australia Standard Time (UTC+09:30).
  • AUS Central Standard Time—The time zone will be AUS Central Standard Time (UTC+09:30).
  • E. Australia Standard Time—The time zone will be E. Australia Standard Time (UTC+10:00).
  • AUS Eastern Standard Time—The time zone will be AUS Eastern Standard Time (UTC+10:00).
  • West Pacific Standard Time—The time zone will be West Pacific Standard Time (UTC+10:00).
  • Tasmania Standard Time—The time zone will be Tasmania Standard Time (UTC+10:00).
  • Vladivostok Standard Time—The time zone will be Vladivostok Standard Time (UTC+10:00).
  • Lord Howe Standard Time—The time zone will be Lord Howe Standard Time (UTC+10:30).
  • Bougainville Standard Time—The time zone will be Bougainville Standard Time (UTC+11:00).
  • Russia Time Zone 10—The time zone will be Russia Time Zone 10 (UTC+11:00).
  • Magadan Standard Time—The time zone will be Magadan Standard Time (UTC+11:00).
  • Norfolk Standard Time—The time zone will be Norfolk Standard Time (UTC+11:00).
  • Sakhalin Standard Time—The time zone will be Sakhalin Standard Time (UTC+11:00).
  • Central Pacific Standard Time—The time zone will be Central Pacific Standard Time (UTC+11:00).
  • Russia Time Zone 11—The time zone will be Russia Time Zone 11 (UTC+11:00).
  • New Zealand Standard Time—The time zone will be New Zealand Standard Time (UTC+12:00).
  • UTC+12—The time zone will be UTC+12 (UTC+12:00).
  • Fiji Standard Time—The time zone will be Fiji Standard Time (UTC+12:00).
  • Kamchatka Standard Time—The time zone will be Kamchatka Standard Time (UTC+12:00).
  • Chatham Islands Standard Time—The time zone will be Chatham Islands Standard Time (UTC+12:45).
  • UTC+13—The time zone will be UTC+13 (UTC+13:00).
  • Tonga Standard Time—The time zone will be Tonga Standard Time (UTC+13:00).
  • Samoa Standard Time—The time zone will be Samoa Standard Time (UTC+13:00).
  • Line Islands Standard Time—The time zone will be Line Islands Standard Time (UTC+14:00).
String; Field
Derived output
Updated Input Table
The updated input table.
Table View
Environments
Current Workspace, Time Zone
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
