Create Role (Data Management Tools)
Summary
Creates a database role, allowing you to add users to or remove them from the role.
Usage
  • This tool can be used with Oracle, Microsoft SQL Server, or PostgreSQL only.
  • You cannot use delimiters, such as double quotation marks, when specifying the role. The role can only contain characters supported by the underlying database management system when provided without delimiters.
Parameters
Label Explanation Data type
Input Database Connection
The connection file to a database or enterprise geodatabase. Connect as a database administrator user.
Workspace
Role
The name of the database role to create. If it's an existing role, type the name for the role you want to add users to or remove them from.
String
Grant To or Revoke From User(s)
(Optional)
Specifies whether the role will be added to a user or list of users or a user or list of users will be removed from the role.
  • Grant role—The role will be granted to the specified user or users, making them a member of the role. This is the default.
  • Revoke role—The role will be revoked from the specified user or users, removing them from the role.
String
User Name(s)
(Optional)
The name of the user whose role membership will change. To specify multiple users, type the user names separated by commas (no spaces).
String
Derived output
Create Role Succeeded
Whether the tool completed successfully.
Boolean
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
