Create Unregistered Table (Data Management Tools)
Summary
Creates an empty table in an enterprise database, enterprise geodatabase, GeoPackage, or SQLite database. The table is not registered with the geodatabase.
Usage
  • The empty table created by this tool will either have a field named OBJECTID of type integer or contain the same field names and types of any selected input template table.
  • Unregistered tables can be registered with the geodatabase using the Register With Geodatabase tool.
Parameters
Label Explanation Data type
Table Location
The enterprise database or enterprise geodatabase in which the table will be created.
Workspace
Table Name
The name of the table that will be created.
String
Template Datasets
(Optional)
An existing dataset or list of datasets with fields and attribute schema that will be used to define the fields in the output table.
Table View
Configuration Keyword
(Optional)
Specifies the default storage parameters (configurations) for geodatabases in a relational database management system (RDBMS). This setting is applicable only when using enterprise geodatabase tables.
Configuration keywords are set by the database administrator.
Learn more about configuration keywords
String
Derived output
Output Table
The output unregistered table.
Table
Environments
Current Workspace, Output CONFIG Keyword
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
