Delete Rows (Data Management Tools)
Summary
Deletes all or the selected subset of rows from the input.
The deletion of all rows or a subset of rows depends on the following:
  • If the input is a feature class or table, all rows will be deleted.
  • If the input is a layer or table view with no selection, all rows will be deleted.
  • If the input is a layer or table view with a selection, only the selected rows will be deleted.
Usage
  • The Input Rows parameter value can be a dBASE table, an enterprise or file geodatabase table or feature class, shapefile, layer, or table view.
  • If this tool is used on feature data, the entire row, including the geometry, will be deleted.
    Deleting all rows from a table with a large number of rows can take time. If the intent is to delete all the rows, consider using the Truncate Table tool instead. See the Truncate Table documentation for important cautionary statements on its use.
Parameters
Label Explanation Data type
Input Rows
The feature class, layer, table, or table view whose rows will be deleted.
Table View
Derived output
Updated Input With Rows Removed
The updated input.
Table View
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
