Delete Schema Geodatabase (Data Management Tools)
Summary
Deletes a geodatabase from a user's schema in Oracle.
Usage
  • The Delete Schema Geodatabase tool only deletes user-schema geodatabases in Oracle; it cannot delete the sde geodatabase.
  • Only the owner of the schema geodatabase can run the Delete Schema Geodatabase tool.
  • You must remove all data from the user-schema geodatabase before you can delete the geodatabase.
Parameters
Label Explanation Data type
Input Database Connection
The database connection file (.sde) of the user-schema geodatabase to be deleted. You must connect as the schema owner.
Workspace
Derived output
Updated Input Workspace
The updated input workspace.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
