Delete Version (Data Management Tools)
Summary
Deletes the specified version from the input enterprise geodatabase.
Usage
  • Traditional versioning—The version owner or the geodatabase administrator can delete a traditional version. For more information, see Delete a traditional version.
  • Branch versioning—The version owner or the version administrator for the web feature layer can delete a branch version. For more information, see Delete a branch version.
    License:
    When working with branch versioned data from a web feature layer data source, organization members may need the ArcGIS Advanced Editing user type extension. For more information, see License requirements for the Version Management service.
Parameters
Label Explanation Data type
Input Workspace
The database connection file to the enterprise geodatabase containing the version that will be deleted.
For branch versioning, use a feature service URL (that is, https://mysite.mydomain/server/rest/services/ElectricNetwork/FeatureServer) or a feature layer portal item.
You can also delete a branch version using a database connection file (connected to a branch versioned workspace) when connected as the geodatabase admin user.
Workspace
Version Name
The name of the version that will be deleted.
For branch versioning, if the input workspace is a database connection file, the name of the branch version to delete should be fully qualified (for example, servicename.portaluser.versionname). If the input workspace is a feature service URL, the name of the branch version to delete should not include the service name (for example, portaluser.versionname).
String
Derived output
Updated Geodatabase
The updated input workspace.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: Limited
    Supported for branch versioning when using named user licensing.
  • Standard: Yes
  • Advanced: Yes
