Diagnose Version Metadata (Data Management Tools)
Summary
Identifies inconsistencies in the system tables used to manage traditional versions and states in a geodatabase.
Usage
  • This tool can be run on enterprise geodatabases.
  • This tool does not support geodatabases in SAP HANA because they don't support traditional versioning.
  • Only the geodatabase administrator can run the Diagnose Version Metadata tool.
  • This tool is usually run at the direction of Esri Technical Support.
Parameters
Label Explanation Data type
Input Database Connection
The database connection (.sde file) to the enterprise geodatabase in which traditional versioning system table inconsistencies may exist.
The connection must be made as the geodatabase administrator.
Workspace
Diagnostic Version Metadata Log
The name and location of the output log file.
The log file is an ASCII file containing a list of the system tables in the specified version that contain inconsistent records, as well as the database connection file used.
File
Derived output
Updated Input Workspace
The updated input workspace.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
