Disable Archiving (Data Management Tools)
Summary
Disables archiving on a geodatabase feature class, table, or feature dataset.
Learn more about the process of disabling archiving
Usage
  • Archiving is only supported on enterprise geodatabases. File and personal geodatabases do not support archiving.
  • The input dataset must be from a database connection established as the data owner.
Parameters
Label Explanation Data type
Input Dataset
The geodatabase feature class, table, or feature dataset for which archiving will be disabled.
Table; Feature Class; Feature Dataset
Preserve History Table
(Optional)
Specifies whether records that are not from the current moment will be preserved.
If the table or feature class is versioned, the history table or feature will become enabled.
For nonversioned data, a table or feature class will be created that contains the history information. The name of the new dataset will be the same as the input with an appended _h.
  • Checked—Records that are not from the current moment will be preserved. This is the default.
  • Unchecked—Records that are not from the current moment will not be preserved; they will be deleted.
Boolean
Derived output
Updated Input Dataset
The updated input dataset.
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
