Enable Archiving (Data Management Tools)
Summary
Enables archiving on a table, feature class, or feature dataset.
Usage
Enabling archiving provides the functionality to record and access changes made to a dataset over time.
Archiving is only supported on enterprise and mobile geodatabases. File geodatabases do not support archiving.
The input dataset must be from a database connection established as the data owner.
Archiving can be enabled on traditional versioned datasets in an enterprise geodatabase or on nonversioned datasets in an enterprise geodatabase or mobile geodatabase. Branch versioned datasets have archiving enabled automatically during the register a dataset as branch versioned process.
Parameters
| Label | Explanation | Data type |
Input Dataset |
The name of the dataset on which archiving will be enabled. |
Table; Feature Class; Feature Dataset |
Derived output
Updated Dataset |
The updated input dataset. |
Environments
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
