Get Count (Data Management Tools)
Summary
Returns the total number of rows for a table.
Usage
  • If the input is a layer or table view containing a selected set of records, only the selected records will be counted.
  • This tool honors the Extent environment. Only those features that are within or intersect the Extent environment setting will be counted.
  • You can view the returned row count in Geoprocessing history.
  • In ModelBuilder, this tool can be used to set up a precondition, as illustrated below. In this model, the Get Count tool counts the number of records returned by the Select tool. If the count is zero, the Buffer tool will not run due to the precondition.
    Using Get Count with a precondition
Parameters
Label Explanation Data type
Input Rows
The input table view or raster layer. If a selection is defined on the input, the count of the selected rows will be returned.
Table View; Raster Layer
Derived output
Row Count
The total number of rows for the input.
Long
Environments
Current Workspace, Extent
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
