Make Mosaic Layer (Data Management Tools)
Summary
Creates a mosaic layer from a mosaic dataset or layer file. The layer that is created by the tool is temporary and will not persist after the session ends unless the layer is saved as a layer file or the map is saved.
This tool can be used to make a layer so you can work with a specified subset of bands in a mosaic dataset.
Usage
  • To persist your layer, right-click the layer in the Contents Pane and click Save As Layer File, or use the Save To Layer File tool.
  • The output can be created with only a subset of the bands. This will save time and disk space.
Parameters
Label Explanation Data type
Mosaic Dataset
The path and name of the input mosaic dataset.
Mosaic Layer
Output Mosaic Layer
The name of the output mosaic layer.
Mosaic Layer
Expression
(Optional)
Define a query using SQL or use the Query Builder to build a query.
SQL Expression
Template Extent
(Optional)
The output extent can be specified by defining the four coordinates or by using the extent of an existing layer.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Bands
(Optional)
The bands that will be exported for the layer. If no bands are specified, all the bands will be used in the output.
Value Table
Mosaic Method
(Optional)
Choose the mosaic method. The mosaic method defines how the layer is created from different rasters in the mosaic dataset.
  • Closest to center—Sorts rasters based on an order where rasters that have their center closest to the view center are placed on top.
  • Northwest—Sorts rasters based on an order where rasters that have their center closest to the northwest are placed on top.
  • Lock raster—Enables a user to lock the display of single or multiple rasters, based on an ID or name. When you choose this option, you need to specify the Lock Raster ID.
  • By attribute—Sorts rasters based on an attribute field and its difference from the base value. When this option is chosen, the order field and order base value parameters also need to be set.
  • Closest to nadir—Sorts rasters based on an order where rasters that have their nadir position closest to the view center are placed on top. The nadir point can be different from the center point, especially in oblique imagery.
  • Closest to view point—Sorts rasters based on an order where the nadir position is closest to the user-defined viewpoint location and are placed on top.
  • Seamline—Cuts the rasters using the predefined seamline shape for each raster using optional feathering along the seams. The ordering is predefined during seamline generation. The LAST mosaic operator is not valid with this mosaic method.
String
Order Field
(Optional)
Choose the order field. When the mosaic method is By attribute, the default field to use when ordering rasters needs to be set. The list of fields is defined as those in the service table that are of type metadata.
String
Order Base Value
(Optional)
The order base value. The images are sorted based on the difference between this value and the attribute value in the specified field.
String
Lock Raster ID
(Optional)
The Raster ID or raster name to which the service should be locked so that only the specified rasters are displayed. If left undefined, it will be similar to the system default. Multiple IDs can be defined as a semicolon-delimited list.
String
Sort Order
(Optional)
Choose whether the sort order is ascending or descending.
  • Ascending—The sort order will be ascending. This is the default.
  • Descending—The sort order will be descending.
String
Mosaic Operator
(Optional)
Choose the mosaic operator to use. When two or more rasters have the same sort priority, this parameter is used to further refine the sort order.
  • First—The first raster in the list will be on top. This is the default.
  • Last—The last raster in the list will be on top.
  • Minimum—The raster with the lowest value will be on top.
  • Maximum—The raster with the highest value will be on top.
  • Mean—The average pixel value will be on top.
  • Blend—The output cell value will be a blend of values; this blend value relies on an algorithm that is weight based and dependent on the distance from the pixel to the edge within the overlapping area.
  • Sum—The output cell value will be the aggregate of all overlapping cells.
String
Output Cell Size
(Optional)
The cell size of the output mosaic layer.
Double
Processing Template
(Optional)
The raster function processing template that can be applied on the output mosaic layer.
  • None—No processing template.
String
Environments
Extent, Geographic Transformations, Output Coordinate System
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
