Package Locator (Data Management Tools)
Summary
Packages a locator or composite locator and creates a single compressed .gcpk file.
Learn more about sharing an address locator as a locator package
Illustration
Package Locator tool illustration
This illustration shows the folder structures of an unpacked locator package that contains a locator and an unpacked composite locator package that contains the composite locator and its participating locators.
Usage
  • To create a package for a composite locator, ensure that the participating locators are stored in the file folder.
  • A warning is issued when this tool encounters an invalid locator. The invalid locator will not be packaged.
  • The locator package file (.gcpk) can be shared with other users.
    Learn more about sharing an address locator as a locator package.
  • You can use the Extract Package tool and specify an output folder to unpack a locator package. You can also specify a folder in which to unpack packages in the Share and download options.
  • Each locator will be copied to a unique folder created in the consolidated folder.
Parameters
Label Explanation Data type
Input Locator
The locator or composite locator that will be packaged.
Address Locator
Output File
The name and location of the output locator package (.gcpk).
File
Composite locator only: copy participating locators in enterprise database instead of referencing them
(Optional)
This parameter has no effect in ArcGIS Pro. It remains only to support backward compatibility.
Boolean
Additional Files
(Optional)
The additional files that will be included in the package.
File
Summary
(Optional)
The text that will be used as the output package's summary property.
String
Tags
(Optional)
The tag information that will be added to the properties of the package. Multiple tags can be added, separated by a comma or semicolon.
String
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
