Package Result (Data Management Tools)
Summary
Packages one or more geoprocessing results, including all tools and input and output datasets, into a single compressed file (.gpkx).
Usage
  • When a tool is run, a geoprocessing history item is added to the Geoprocessing History section of the Catalog pane. Use this item as input to the Package Result tool.
    When a tool is run from Python, a Result object is returned. The Result object's resultID property can be used as input to this tool. The second code sample below demonstrates how to use a Result object's resultID property.
  • When Support ArcGIS Maps SDKs is checked, the geoprocessing package created can be used in the ArcGIS Maps SDKs environment. To support the ArcGIS Maps SDKs environment, the following occur:
    • All nongeodatabase data sources are converted to a file geodatabase.
    • A copy of the tool being package is created in a new toolbox configured for publishing.
    Starting at ArcGIS Pro 2.1, geoprocessing packages that support ArcGIS Maps SDKs can be created.
  • When the Convert data to file geodatabase parameter is checked, the following occurs:
    • Each unique data source will have a file geodatabase created in the consolidated folder or package.
    • Compressed raster and vector formats will be converted to a file geodatabase, and compression will be lost.
    • Enterprise geodatabase data will not be consolidated. To convert enterprise geodatabase data to a file geodatabase, check the Include Enterprise Geodatabase data instead of referencing the data parameter.
  • When the Convert data to file geodatabase parameter is not checked, the following occurs:
    • The data source format of the input layers will be preserved when possible.
    • ADRG, CADRG/ECRG, CIB, and RPF raster formats will be converted to file geodatabase rasters. ArcGIS cannot natively write out these formats. They will be converted to file geodatabase rasters for efficiency.
    • In the output folder structure, file geodatabases will be consolidated in a version-specific folder, and all other formats will be consolidated in the commonData folder.
    • Compressed raster and vector formats will not be clipped even if an extent is specified for the Extent parameter.
  • For layers that contain a join or participate in a relationship class, all joined or related data sources will be consolidated into the output folder. By default, joined or related data sources will be consolidated in their entirety or, depending on the Select Related Rows parameter value, based on the extent specified for the Extent parameter.
  • For feature layers, the Extent parameter is used to select the features that will be consolidated. For raster layers, the Extent parameter is used to clip the raster datasets.
  • Some datasets reference other datasets. For example, a topology dataset may reference four feature classes. Other examples of datasets that reference other datasets include geometric networks, networks, and locators. When consolidating or packaging a layer based on these types of datasets, the participating datasets will also be consolidated or packaged.
  • If the Schema only parameter is checked, only the schema of the input and output data sources will be consolidated or packaged. A schema is the structure or design of a feature class or table that consists of field and table definitions, coordinate system properties, symbology, definition queries, and so on. Data and records will not be consolidated or packaged.
  • Data sources that do not support schema only will not be consolidated or packaged. If the Schema only parameter is checked and the tool encounters a layer that is not supported for schema only, a warning message appears and that layer will be skipped. If the only layer specified is unsupported for schema only, the tool will fail.
  • To unpack a geoprocessing package, use the Extract Package tool to extract the contents to a folder. You can then browse to the directory and explore the tool and data. Alternatively, right-click the package from a folder in the Catalog pane and extract it to the current map. The tool will be accessible from the Geoprocessing History section.
    By default, when extracting a package from the Catalog pane, the contents will be extracted into your user profile.
Parameters
Label Explanation Data type
Result
The result that will be packaged.
The input can be either a result from the history of the current project or a Result object's resultID property when the tool is being used in a Python script.
File; String
Output File
The name and location of the output package file (.gpkx).
File
(Optional)
Specifies whether input layers will be converted to a file geodatabase or preserved in their original format.
  • Checked—Data will be converted to a file geodatabase. This option does not apply to enterprise geodatabase data sources. To include enterprise geodatabase data, check the Include Enterprise Geodatabase data instead of referencing the data parameter.
  • Unchecked—Data formats will be preserved when possible. This is the default.
Boolean
(Optional)
Specifies whether input enterprise geodatabase layers will be converted to a file geodatabase or preserved in their original format.
  • Checked—Enterprise geodatabase data will be converted to a file geodatabase and will be included in the consolidated folder or package. This is the default.
  • Unchecked—Enterprise geodatabase data will be preserved and will be referenced in the consolidated folder or package.
Boolean
Extent
(Optional)
Specifies the extent that will be used to select or clip features.
  • Current Display Extent Map View—The extent will be based on the active map or scene.
  • Draw Extent Square and Finish—The extent will be based on a rectangle drawn on the map or scene.
  • Extent of a Layer Layer—The extent will be based on an active map layer. Choose an available layer or use the Extent of data in all layers option. Each map layer has the following options:
    • All Features Select All—The extent of all features.
    • Selected Features Area from Selected Features—The extent of the selected features.
    • Visible Features Extent Indicator—The extent of visible features.
  • Browse Browse—The extent will be based on a dataset.
  • Intersection of Inputs Intersect—The extent will be the intersecting extent of all inputs.
  • Union of Inputs Union—The extent will be the combined extent of all inputs.
  • Clipboard Paste—The extent can be copied to and from the clipboard.
    • Copy Extent Copy—Copies the extent and coordinate system to the clipboard.
    • Paste Extent Paste—Pastes the extent and coordinate system from the clipboard. If the clipboard does not include a coordinate system, the extent will use the map's coordinate system.
  • Reset Extent Reset—The extent will be reset to the default value.
When coordinates are manually provided, the coordinates must be numeric values and in the active map's coordinate system. The map may use different display units than the provided coordinates. Use a negative value sign for south and west coordinates.
Extent
Apply extent only to enterprise geodatabase layers
(Optional)
Specifies whether the specified extent will be applied to all layers or to enterprise geodatabase layers only.
  • Checked—The specified extent will be applied to enterprise geodatabase layers only.
  • Unchecked—The specified extent will be applied to all layers. This is the default.
Boolean
Schema only
(Optional)
Specifies whether all records for input and output datasets or only the schema of input and output datasets will be consolidated or packaged.
  • Checked—Only the schema of input and output datasets will be consolidated or packaged.
  • Unchecked—All records for input and output datasets will be consolidated or packaged. This is the default.
Boolean
(Optional)
Specifies whether the package will support ArcGIS Maps SDKs. To support ArcGIS Maps SDKs, all data sources will be converted to a file geodatabase.
  • Checked—The output package will support ArcGIS Maps SDKs.
  • Unchecked—The output package will not support ArcGIS Maps SDKs. This is the default.
Boolean
Additional Files
(Optional)
The additional files that will be included in the package.
File
Summary
(Optional)
The text that will be used as the output package's summary property.
String
Tags
(Optional)
The tag information that will be added to the properties of the package. Multiple tags can be added, separated by a comma or semicolon.
String
Package Version
(Optional)
Specifies the ArcGIS Pro version that certain objects such as projects, maps, and layers will be compatible with and persisted to. Saving to an earlier version can be helpful if the project will be used with older software.
Caution:
A package saved to an earlier version may lose functionality or properties that are not supported in the earlier version.
  • All versions—The contents of the package will be compatible with all versions (ArcGIS Pro 2.1 and later).
  • Current version—The contents of the package will be compatible with the current version of the ArcGIS Pro release.
  • ArcGIS Pro 2.2—The contents of the package will be compatible with ArcGIS Pro version 2.2.
  • ArcGIS Pro 2.3—The contents of the package will be compatible with ArcGIS Pro version 2.3.
  • ArcGIS Pro 2.4—The contents of the package will be compatible with ArcGIS Pro version 2.4.
  • ArcGIS Pro 2.5—The contents of the package will be compatible with ArcGIS Pro version 2.5.
  • ArcGIS Pro 2.6—The contents of the package will be compatible with ArcGIS Pro version 2.6.
  • ArcGIS Pro 2.7—The contents of the package will be compatible with ArcGIS Pro version 2.7.
  • ArcGIS Pro 2.8—The contents of the package will be compatible with ArcGIS Pro version 2.8.
  • ArcGIS Pro 2.9—The contents of the package will be compatible with ArcGIS Pro version 2.9.
  • ArcGIS Pro 3.0—The contents of the package will be compatible with ArcGIS Pro version 3.0.
  • ArcGIS Pro 3.1—The contents of the package will be compatible with ArcGIS Pro version 3.1.
  • ArcGIS Pro 3.2—The contents of the package will be compatible with ArcGIS Pro version 3.2.
  • ArcGIS Pro 3.3—The contents of the package will be compatible with ArcGIS Pro version 3.3.
  • ArcGIS Pro 3.4—The contents of the package will be compatible with ArcGIS Pro version 3.4.
  • ArcGIS Pro 3.5—The contents of the package will be compatible with ArcGIS Pro version 3.5.
  • ArcGIS Pro 3.6—The contents of the package will be compatible with ArcGIS Pro version 3.6.
  • ArcGIS Pro 3.7—The contents of the package will be compatible with ArcGIS Pro version 3.7.
String
Keep only the rows that are related to features within the extent
(Optional)
Specifies whether the specified extent will be applied to related data sources.
  • Checked—Only related data corresponding to records within the specified extent will be consolidated.
  • Unchecked—Related data sources will be consolidated in their entirety. This is the default.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
