Pivot Table (Data Management Tools)
Summary
Creates a table from the input table by reducing redundancy in records and flattening one-to-many relationships.
Illustration
Usage
This tool is typically used to reduce redundant records and flatten one-to-many relationships.
The combination of the Input Fields, Pivot Field, and Value Field parameter values must be unique. Use the Frequency tool to determine if the combination is unique.
If the Pivot Field value is a text field, its values must begin with a character (for example, a2) and not a number (for example, 2a). If the value of the first record begins with a number, all the output values will be 0.
If the Pivot Field value is a numeric type, its value will be appended to its original field name in the output table.
The number of fields in the output table will be determined by the number of input fields you specify, plus one field for each unique Pivot Field value. The number of records in the output table will be determined by the unique combination of values between the specified input fields and the pivot field.
The tool will fail if the Pivot Field value contains Null values.
Parameters
| Label | Explanation | Data type |
Input Table |
The table containing the records that will be pivoted. |
Table View |
Input Fields |
The fields that define the records that will be included in the output table. |
Field |
Pivot Field |
The field whose record values will be used to generate the field names in the output table. |
Field |
Value Field |
The field whose values will populate the pivoted fields in the output table. |
Field |
Output Table |
The table that will be created containing the pivoted records. |
Table |
Environments
Current Workspace, Output CONFIG Keyword, Scratch Workspace
Licensing information
- Basic: No
- Standard: No
- Advanced: Yes
