Raster Compare (Data Management Tools)
Summary
Compares the properties of two raster datasets or two mosaic datasets.
Usage
  • The tool returns messages showing the comparison result.
  • The parameter and attribute tolerances allow the comparisons to have a specified amount of deviation.
  • When using this tool in Python, get the status of the comparison from the returned Result object using the index position of 1.(result[1]). The value will be 'true' when no differences are found and 'false' when differences are found.
    Learn more about using tools in Python
Parameters
Label Explanation Data type
Input Base Raster
The raster or mosaic dataset that will be compared with the Input Test Raster parameter value. This parameter value is data that you have declared valid. This base data has the correct content and information.
Raster Layer; Mosaic Layer
Input Test Raster
The raster or mosaic dataset that will be compared with the Input Base Raster parameter value. This parameter value is data that you have made changes to by editing or compiling new information.
Compare Type
(Optional)
Specifies the type of rasters that will be compared.
  • Raster dataset—Two raster datasets will be compared.
  • Geodatabase raster dataset—Two raster datasets in a geodatabase will be compared.
  • Mosaic dataset—Two mosaic datasets will be compared.
String
Ignore Options
(Optional)
Specifies the properties that will be ignored in the comparison.
  • Band count—The number of bands will be ignored.
  • Extent—The extent will be ignored.
  • Columns and rows—The number of columns and rows will be ignored.
  • Pixel type—The pixel type will be ignored.
  • NoData—The NoData value will be ignored.
  • Spatial reference—The spatial reference system will be ignored.
  • Pixel value—The pixel values will be ignored.
  • Colormap—Existing color maps will be ignored.
  • Raster attribute table—Existing attribute tables will be ignored.
  • Statistics—Statistics will be ignored.
  • Metadata—Metadata will be ignored.
  • Pyramids exist—Existing pyramids will be ignored.
  • Compression type—The compression type will be ignored.
  • Data source type—The data source type will be ignored.
String
Continue Comparison
(Optional)
Specifies whether the comparison will continue after encountering the first difference between the inputs.
  • Checked—The tool will continue after encountering the first difference.
  • Unchecked—The tool will stop after encountering the first difference. This is the default.
Boolean
Output Compare File
(Optional)
The output file that will contain all similarities and differences between the inputs. This file is a comma-delimited text file that can be viewed and used as a table in ArcGIS.
File
Parameter Tolerance
(Optional)
The tolerances that determine the range in which values will be considered equal. The same tolerance can be applied to all parameters, or different tolerances can be applied to individual parameters.
The tolerance type can be either a value or a fraction.
If the tolerance type is a fraction, the tolerance for each pixel will be different since each pixel has a different value. For example, if a tolerance fraction is set to 0.5, the tolerance will be calculated as follows:
  • If a pixel has a value of 0.2, the tolerance will be 0.1, since 0.5 * 0.2 = 0.1.
  • If a pixel has a value of 3, the tolerance will be 1.5, since 0.5 * 3 = 1.5.
Value table columns:
  • Parameter—There are seven types of parameter tolerances you can adjust.
    • All—The extents, pixel values, minimums, maximums, means, and standard deviations will be compared to determine if they are equal within the specified tolerance.
    • Extent—If the difference of the extents is within the tolerance, they will be considered equal.
    • Pixel values—If the difference of the pixel values is within the tolerance, they will be considered equal.
    • Minimum—If the difference of the minimum values is within the tolerance, they will be considered equal.
    • Maximum—If the difference of the maximum values is within the tolerance, they will be considered equal.
    • Mean—If the difference of the mean values is within the tolerance, they will be considered equal.
    • Standard deviation—If the difference of the standard deviations is within the tolerance, they will be considered equal.
  • Tolerance—Set the tolerance type to a specified value or use that value as a fraction.
  • Type—Set the type of tolerance value for the selected parameter.
    • Fraction—The tolerance value will be a fraction of the value specified.
    • Value—The tolerance value will be the value specified.
Value Table
Attribute Tolerance
(Optional)
The numeric value that will determine the range in which attribute values are considered equal. This parameter only applies to numeric field types.
  • Field—The numeric field that the tolerance will be applied to.
  • Tolerance—The numeric value that determines the range in which attribute values are considered equal. This only applies to numeric field types.
Value Table
Omit Fields
(Optional)
The field or fields that will be omitted during comparison. The field definitions and the tabular values for these fields will be ignored.
String
Out Compare Raster
(Optional)
The output raster comprising the differences between the Input Base Raster and Input Test Raster parameter values.
Raster Dataset
Derived output
Compare Status
The compare status will be 'true' when no differences are found and 'false' when differences are found.
Boolean
Environments
Current Workspace, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
