Repair Version Tables (Data Management Tools)
Summary
Repairs inconsistencies in the delta (A and D) tables of datasets that are registered for traditional versioning.
Usage
  • Run the Diagnose Version Tables tool to determine if there are inconsistencies in your geodatabase delta tables before you run the Repair Version Tables tool.
  • This tool can only be run on an enterprise geodatabase.
  • This tool does not support geodatabases in SAP HANA because they don't support traditional versioning.
  • Only the geodatabase administrator can run this tool.
  • Always create a database backup before running this tool.
Parameters
Label Explanation Data type
Input Database Connection
The database connection (.sde file) to the enterprise geodatabase in which delta table inconsistencies exist. The connection must be made as the geodatabase administrator.
Workspace
Repair Version Tables Log
The location where the log file will be written and the name of the log file. The log file is an ASCII file containing the results of the repair operation.
File
Target Version
(Optional)
The geodatabase version to be repaired. The drop-down list is populated with the existing versions in the geodatabase specified for the Input Database Connection parameter. If no version is selected, all versions are processed.
String
Input Tables
(Optional)
A single table or a text file containing a list of versioned tables with the associated delta tables to be repaired. Use fully-qualified table names in the text file, and place one table name per line. If no table or file is specified, all tables are processed.
String
Derived output
Repaired Geodatabase
The repaired geodatabase.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: No
  • Standard: Yes
  • Advanced: Yes
