Shape manipulation
Shape manipulation functions can be applied in the Geometry row of the Expression column in a Mapping workbook. The functions are used to define how geometry will be transformed when loading data from the source to the target. This transformation can include converting between geometry types.
The sections below describe the available shape manipulation functions.
Polygon to Point
The Polygon to Point function transforms a polygon into a point using the centroid of the polygon. The function is automatically selected in the Mapping workbook when the source is a polygon and the target is a point.
Illustration
Syntax
polygon_to_point(shape)
Name
Explanation
Data type
shape
The field that contains shape geometry.
Geometry
Example
polygon_to_point(!Shape!)
Polygon to Multipoint
The Polygon to Multipoint function transforms a polygon into a multipoint with a point at each vertex of the source polygon. The function is automatically selected in the Mapping workbook when the source is a polygon and the target is a multipoint.
Illustration
Syntax
polygon_to_multipoint(shape)
Name
Explanation
Data type
shape
Geometry
Example
polygon_to_multipoint(!Shape!)
Polygon to Diameter Polyline
The Polygon to Diameter Polyline function transforms a polygon into a single segment polyline that connects the two vertices of the polygon that are farthest apart along its boundary. The function is not automatically selected in the Mapping workbook and must be manually entered in the Expression column.
Illustration
Syntax
polygon_to_diameter_polyline(shape)
Name
Explanation
Data type
shape
Geometry
Example
polygon_to_diameter_polyline(!Shape!)
Polygon to Polyline
The Polygon to Polyline function transforms a polygon into a polyline using the polygon's boundary. The function is automatically selected in the Mapping workbook when the source is a polygon and the target is a polyline.
Illustration
Syntax
polygon_to_polyline(shape)
Name
Explanation
Data type
shape
Geometry
Example
polygon_to_polyline(!Shape!)
Polyline to Polygon
The Polyline to Polygon function transforms a polyline into a polygon using a specified buffer distance. The function is automatically selected in the Mapping workbook when the source is a polyline and the target is a polygon.
Illustration
Syntax
polyline_to_polygon(shape, distance)
Name
Explanation
Data type
shape
Geometry
distance
The distance around the input feature that will be buffered.
Double
Example
polyline_to_polygon(!Shape!, 20)
Polyline to Point
The Polyline to Point function transforms a polyline into a point using a ratio of the length of the line. The function is automatically selected in the Mapping workbook when the source is a polyline and the target is a point.
Illustration
Syntax
polyline_to_point(shape, {ratio})
Name
Explanation
Data type
shape
Geometry
ratio (Optional)
The distance along the line where the point will be placed, expressed as a ratio from 0 to 1. The default value is 0.5.
Double
Example
polyline_to_point(!Shape!, 0.5)
Polyline to Multipoint
The Polyline to Multipoint function transforms a polyline into a multipoint, creating a point at each vertex of the source polyline. The function is automatically selected in the Mapping workbook when the source is a polyline and the target is a multipoint.
Illustration
Syntax
polyline_to_multipoint(shape)
Name
Explanation
Data type
shape
Geometry
Example
polyline_to_multipoint(!Shape!)
Point to Polygon
The Point to Polygon function transforms a point into a polygon using a specified buffer distance. The function is automatically selected in the Mapping workbook when the source is a point and the target is a polygon.
Illustration
Syntax
point_to_polygon(shape, distance)
Name
Explanation
Data type
shape
Geometry
distance
Double
Example
point_to_polygon(!Shape!, 50)
Point to Polyline
The Point to Polyline function transforms a point into a polyline using a specified distance and angle. The function is automatically selected in the Mapping workbook when the source is a point and the target is a polyline.
The starting vertex for the generated line will be the same location as the source point.
Illustration
Syntax
point_to_polyline(shape, angle, distance)
Name
Explanation
Data type
shape
Geometry
angle
The angle at which the polyline will be generated. The angle must be between 0 and 360.
Double
distance
Double
Example
point_to_polyline(!Shape!, 30, 100)
Point to Multipoint
The Point to Multipoint function transforms a point into a multipoint with a collection of randomly generated points centered around the source point. The function is automatically selected in the Mapping workbook when the source is a point and the target is a multipoint.
Illustration
Syntax
point_to_multipoint(shape, num_points, radius)
Name
Explanation
Data type
shape
Geometry
num_points
The number of points to be randomly generated.
Short
radius
The radius in which the randomly generated points will be dispersed within.
Double
Example
point_to_multipoint(!Shape!, 30, 200)
Multipoint to Polygon
The Multipoint to Polygon function transforms a multipoint into a polygon using the convex hull of the source multipoint. The function is automatically selected in the Mapping workbook when the source is a multipoint and the target is a polygon.
If the multipoint feature is only one or two points, a polygon buffer will be generated at a default buffer size. If the multipoint feature is greater than two points, it will use the convex hull method for polygon generation.
Illustration
Syntax
multipoint_to_polygon(shape)
Name
Explanation
Data type
shape
Geometry
Example
multipoint_to_polygon(!Shape!)
Multipoint to Polyline
The Multipoint to Polyline function transforms a multipoint into a polyline using the convex hull of the source multipoint. The function is automatically selected in the Mapping workbook when the source is a multipoint and the target is a polyline.
If the multipoint feature is a single point, a polyline will be generated at a default direction and length. If the multipoint feature is two points or greater, it will use the convex hull method for polyline generation.
Illustration
Syntax
multipoint_to_polyline(shape)
Name
Explanation
Data type
shape
Geometry
Example
multipoint_to_polyline(!Shape!)
Multipoint to Point
The Multipoint to Point function transforms a multipoint into a point using the centroid of the source multipoint. The function is automatically selected in the Mapping workbook when the source is a multipoint and the target is a point.
Illustration
Syntax
multipoint_to_point(shape)
Name
Explanation
Data type
shape
Geometry
Example
multipoint_to_point(!Shape!)
Create Point
The Create Point function creates a point from x- and y-coordinates in a table. You can also include z, m, and spatial reference information. The function is automatically selected in the Mapping workbook when the source is a table and the target is a point.
Syntax
create_point(x, y, {z}, {m}, {spatial_reference})
Name
Explanation
Data type
x
The x-value or the field that contains the x-value.
Double
y
The y-value or the field that contains the y-value.
Double
z (Optional)
The z-value or the field that contains the z-value.
Double
m (Optional)
The m-value or the field that contains the m-value.
Double
spatial_reference (Optional)
The horizontal coordinate system that defines the spatial reference. The coordinate system can be set using a projection file, name, or factory code.
SpatialReference
Example
create_point(!x!, !y!, !z!, !m!, 8745)
Move Feature
The Move Feature function moves the x-, y-, and z-coordinates of any geometry type by a value. The function is not automatically selected in the Mapping workbook and must be manually entered in the Expression column.
Syntax
move(shape, {x}, {y}, {z})
Name
Explanation
Data type
shape
Geometry
x (Optional)
The amount to shift the x-value.
Double
y (Optional)
The amount to shift the y-value.
Double
z (Optional)
The amount to shift the z-value.
Double
Example
move(!Shape!, 50, 50, 50)
