Subset Features (Data Management Tools)
Summary
Divides the records of a feature class or table into two subsets: one subset to be used as training data, and one subset to be used as test features to compare and validate the output surface.
Usage
  • In the Random number generator environment, only the Mersenne Twister option is supported. If other options are chosen, Mersenne twister will be used instead.
  • Splitting a dataset into training and test features is common in interpolation, machine learning, and other analytical workflows that involve estimating and building models from data.
  • If multipart features are used as input, the output will be a subset of multipart features, not individual features.
Parameters
Label Explanation Data type
Input Features
The features or table from which subsets will be created.
Table View
Output Training Feature Class
The subset of training features that will be created.
Feature Class; Table
Output Test Feature Class
(Optional)
The subset of test features that will be created.
Size of Training Feature Subset
(Optional)
The size of the output training feature class, entered either as a percentage of the input features or as an absolute number of features.
Double
Subset Size Units
(Optional)
Specifies whether the subset size value will be used as a percentage of the input features or as an absolute number of features.
  • Checked—The subset size will be used as a percentage of the input features that will be in the training dataset.
  • Unchecked—The subset size will be used as the number of features that will be in the training dataset.
Boolean
Environments
Current Workspace, Extent, Geographic Transformations, Output Coordinate System, Random number generator, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
