TIN Compare (Data Management Tools)
Summary
Compares two TINs and returns the comparison results.
Usage
  • This tool returns messages showing the comparison result. By default, the tool will stop running after encountering the first difference between the inputs. To report all differences, check the Continue Comparison parameter.
  • This tool can report differences with geometry, TIN node and triangle tags, and spatial reference.
  • The Output Compare File parameter value will contain all similarities and differences between the Input Base TIN and Input Test TIN parameter values. This file is a comma-delimited text file that can be viewed and used as a table in ArcGIS. For example, it can be queried to obtain all the object ID values for all the rows that are different.
  • When using this tool in Python, get the status of the comparison from the returned Result object using the index position of 1.(result[1]). The value will be 'true' when no differences are found and 'false' when differences are found.
    Learn more about using tools in Python
Parameters
Label Explanation Data type
Input Base Tin
The data that will be compared with the Input Test Tin parameter value. This parameter value is data that you have declared valid. This base data has the correct content and information.
TIN Layer
Input Test Tin
The data that will be compared with the Input Base Tin parameter value. This parameter value is data that you have made changes to by editing or compiling new information.
TIN Layer
Compare Type
(Optional)
Specifies the comparison type that will be used.
  • All—All properties will be compared. This is the default.
  • Properties only—Both geometry and TIN tag values, if any, that are assigned to nodes and triangles will be compared.
  • Spatial Reference only—Coordinate system information will be compared.
String
Continue Comparison
(Optional)
Specifies whether the comparison will continue after encountering the first difference between the inputs.
  • Checked—The tool will continue after encountering the first difference.
  • Unchecked—The tool will stop after encountering the first difference. This is the default.
Boolean
Output Compare File
(Optional)
The output file that will contain all similarities and differences between the inputs. This file is a comma-delimited text file that can be viewed and used as a table in ArcGIS.
File
Derived output
Compare Status
The compare status will be 'true' when no differences are found and 'false' when differences are found.
Boolean
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
