Transpose Fields (Data Management Tools)
Summary
Switches data stored in fields or columns to rows in a new table or feature class.
This tool is useful when a table or feature class stores values in field names (such as Field1, Field2, Field3) that you want to rotate so they're arranged in rows. It lets you switch the field names and the corresponding data values in the fields to rows.
Illustration
Transpose Fields tool illustration
Transpose data values stored in columns of a table or feature class into rows.
Usage
  • By default, the output is a table. When the input is a feature class and the output should be a feature class, add the Shape field to the Attribute Fields parameter.
  • The output Transposed Field and Value Field field types will be text.
Parameters
Label Explanation Data type
Input Table
The input feature class or table containing data value fields that will be transposed.
Table View
Fields To Transpose
The fields containing data values in the input table that will be transposed.
Depending on your requirements, you can select multiple fields to be transposed. The value specified here defines what the field name will be in the output. When no value is specified, the field name will be used. For example, if the field names to be transposed are Pop1991 and Pop1992, the values for these fields in the output will be the same (Pop1991 and Pop1992) by default. However, you can provide other values, such as 1991 and 1992, instead.
Value table columns:
  • Field—The fields or columns in the input table that will be transposed.
  • Value—The new field name that will be in the output. When no value is specified, the value is the same as the field name by default
Value Table
Output Table
The output feature class or table. The output will contain a transposed field, a value field, and any number of specified attribute fields that need to be inherited from the input table.
By default, the value is a table. The output will be a feature class when the Input Table parameter value is a feature class and the Shape field is specified in the Attribute Fields parameter.
Table
Transposed Field
The name of the field that will be created to store field names of the transposed fields. Any valid field name can be used.
String
Value Field
The name of the field that will be created to store the corresponding values of the transposed fields. Any valid field name can be used, as long as it does not conflict with existing field names from the input table or feature class.
String
Attribute Fields
(Optional)
The additional attribute fields from the input table that will be included in the output table. To output a feature class, include the Shape field.
Field
Environments
Current Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
