Uncompress File Geodatabase Data (Data Management Tools)
Summary
Uncompresses all the contents in a geodatabase, all the contents in a feature dataset, or an individual stand-alone feature class or table.
Usage
When you uncompress a geodatabase, all feature classes and tables within it uncompress.
When you uncompress a feature dataset, all its feature classes uncompress.
You cannot individually compress or uncompress a feature class in a feature dataset to produce a mixed state where some feature classes are compressed and others are not. Compressed feature datasets allow you to add an uncompressed feature class through operations such as creating a new, empty feature class, copying and pasting, and importing. However, you cannot edit the uncompressed feature class if there are compressed feature classes in the same feature dataset. Once you've finished adding one or more uncompressed feature classes, you can recompress or uncompress the feature dataset so all its feature classes are either compressed or uncompressed.
Parameters
| Label | Explanation | Data type |
Input file geodatabase data |
The geodatabase, feature dataset, feature class, or table to uncompress. |
Workspace; Feature Dataset; Table View; Raster Layer; Geometric Network |
Configuration keyword (Optional) |
The configuration keyword defining how the data will store once uncompressed |
String |
Derived output
Uncompressed Input Data |
The uncompressed input data. |
Environments
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
