Unregister Replica (Data Management Tools)
Summary
Unregisters a replica from an enterprise geodatabase.
Usage
This tool must be run as the replica owner or the geodatabase administrator. For service-based replicas, the replica owner is the database user on which the service processes were run.
If the replica has a version associated with it, this tool does not delete the version.
Ensure that you no longer need to use the replica before running this tool. Once the replica is unregistered, it can not be used to synchronize changes.
This tool supports replicas created through ArcGIS Desktop or ArcGIS Pro using geodatabase replication or created through a feature service.
Replica names and IDs can be obtained using the Manage Replicas pane or from the feature service's
replicasREST resource.If the feature service from which a replica was created is not accessible or no longer exists, you can use the
arcpy.da.ListReplicasPython function to get a list of all types of replicas created in the geodatabase.
Parameters
| Label | Explanation | Data type |
Input Geodatabase |
The enterprise geodatabase that contains the replica to unregister. |
Workspace |
Replica ID or Name |
The name or ID of the replica that will be unregistered. If providing the replica name, it must be fully qualified, for example, |
String |
Derived output
Updated Geodatabase |
The updated geodatabase with the unregistered replica. |
Workspace |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: No
- Standard: Yes
- Advanced: Yes
