Create Reviewer Session (Data Reviewer Tools)
Summary
Creates a new Reviewer session in a specified workspace.
Legacy:
This tool is based on the Reviewer workspace which has been deprecated at ArcGIS Pro 3.7 and is no longer available. It is recommended that you migrate to ArcGIS Data Reviewer attribute rules-based workflows.
Learn more about migrating to attribute rules
Usage
  • The input workspace must be a Reviewer workspace. Use the Enable Data Reviewer tool to create a Reviewer workspace.
  • The input workspace must contain the current version of the Reviewer schema. If it does not, use the Enable Data Reviewer tool to upgrade the workspace.
  • The Session Template parameter allows you to copy properties from an existing Reviewer session into the new session created by this tool. Properties include the following:
    • Continue batch processing if check fails
    • Continue batch processing if default checks return error
    • Reviewer Table Properties
    • Default checks
    If you use a session template, the following parameters will be disabled:
    • Check For Duplicates
    • Do Not Store Geometry
    • Session User Name
    • Session Version
    To specify these parameter values for the new session, do not choose a session template.
  • The Check For Duplicates parameter specifies how duplicate validation results will be handled in the session. Duplicate errors are those that have matching values in the OBJECTID or IDENTIFIER, REVIEWERCODE, ORIGINTABLE, and PARAMETER fields.
Parameters
Label Explanation Data type
Reviewer Workspace
The workspace where the new Reviewer session will be created.
Workspace
Session Name
The name of the session that will be created in the Reviewer workspace.
String
Session Template
(Optional)
An existing Reviewer session whose properties will be copied to the new session.
String
(Optional)
Specifies how duplicate validation results will be handled in the session.
  • None—No search will be conducted for duplicate validation results. This will improve performance when writing validation results to the database. This is the default.
  • Session—The session will be searched for duplicate validation results.
  • Database—The entire database will be searched for duplicate validation results.
String
(Optional)
Specifies whether results will include an associated geometry.
  • Checked—Results will include only attribute information. This can improve performance when writing validation results to the geodatabase.
  • Unchecked—Results will include both geometry and attribute information. This is the default.
Boolean
Session User Name
(Optional)
The username of the person creating the Reviewer session. The default is the Windows user who is actively logged in.
String
Session Version
(Optional)
The enterprise geodatabase version that the session will be associated with. This parameter is only enabled when the Reviewer workspace is stored in an enterprise geodatabase.
String
Derived output
Reviewer Session
The name of the new Reviewer session created.
String
Environments
Current Workspace
Licensing information
  • Basic: Requires Data Reviewer
  • Standard: Requires Data Reviewer
  • Advanced: Requires Data Reviewer
