Reselect Sample (Data Reviewer Tools)
Summary
Reselects a previously generated random selection from a feature layer or table view. This tool applies a selection using the input data based on the SQL query sourced from a .json file that was generated using the Select Random Sample tool.
Usage
The Input JSON File parameter value stores the following information:
The date and time the tool was run
The workspace the input is sourced from
The name of the input feature layers or tables
The total number of selected records
The OIDs of the selected records
The SQL expression that was used to make the selection
The output
.jsonfile from the Select Random Sample tool stores the SQL query that will be applied to the input feature layer or table view.A new selection will be created on the data. Any selection made before running this tool will be cleared or ignored. The Use the selected records toggle button status will not impact the reselection, as the tool will run on all rows in the feature layer or table specified in the Input Rows parameter.
The feature layer or table must have an
ObjectIDfield before running this tool.If the Use the selected records toggle button is turned off, the Output File parameter value will record a random selection of features based on the entire dataset. However, if there is a definition query applied, only the features or rows matching the query will be selected in the map frame.
Parameters
| Label | Explanation | Data type |
Input Rows |
The feature layer or table view to which the selection will be applied. |
Feature Layer; Table View |
Input JSON File |
The |
File |
Derived output
Updated Rows |
The updated input with a selection applied. |
Environments
Licensing information
- Basic: Requires Data Reviewer
- Standard: Requires Data Reviewer
- Advanced: Requires Data Reviewer
