Set Reviewer Properties (Data Reviewer Tools)
Summary
Set the error management method for your database to either manual or automatic review.
Usage
  • Manual error management sets fixed error results as Resolved and requires manual review to mark them as Acceptable. Automatic error management automatically updates the error status to Acceptable once the error has been resolved.
  • When manual error management is enabled for the first time, the tool creates the GDB_ReviewerExtensionProperties table. This is a required system table that tracks which error management method is used by the geodatabase. Once the management method is set to manual, the minimum ArcGIS Pro release for all authored attribute rules updates to ArcGIS Pro 3.8, unless the release version is already a release higher than ArcGIS Pro 3.8.
  • This tool accepts the following database types:
    • File geodatabase
    • Mobile geodatabase
  • The Workspace parameter value must be a geodatabase that meets the following conditions:
    • Global IDs and Editor Tracking are enabled on at least one feature class.
    • At least one Data Reviewer validation attribute rule is authored.
    • The system generated error tables GDB_ValidationPointErrors, GDB_ValidationLineErrors, GDB_ValidationPolygonErrors, and GDB_ValidationObjectErrors are present.
Parameters
Label Explanation Data type
Input Workspace
The geodatabase where manual error management will be enabled or disabled.
Workspace
Error Management Method
Specifies the error management method that will be used following validation rule evaluation.
The default will be Manual if the GDB_ReviewerExtensionProperties table for error management has not been generated or if the table has been set to automated. The default will be Automatic if the GDB_ReviewerExtensionProperties table for error management is set to manual.
  • Manual—Errors will be manually managed by leaving comments and transitioning error records from the Resolved/Mark As Exception status to the Acceptable/Exception status.
  • Automatic—Error records will automatically transition from the Reviewed status to the Acceptable status upon reevaluation.
String
Derived output
Table
The updated GDB_ReviewerExtensionProperties table.
Table
Environments
Current Workspace
Licensing information
  • Basic: Requires Data Reviewer
  • Standard: Requires Data Reviewer
  • Advanced: Requires Data Reviewer
