Coincident Points (Environment setting)
Tools that honor the Coincident Points environment define how coincident data is treated in Geostatistical Analyst.
Usage notes
  • When the tool used uses more than one dataset and the datasets have coincident points, the environment setting is applied to all datasets.
Dialog syntax
  • Mean of values at coincident locations—The mean of the data at the coincident location will be used. This is the default.
  • Exclude all coincident data—Coincident data will be excluded from the analysis.
  • Minimum value at coincident locations—The minimum value of the data at the coincident location will be used.
  • Maximum value at coincident locations—The maximum value of the data at the coincident location will be used.
  • Include all coincident data—All the data will be used.
Python syntax
arcpy.env.coincidentPoints = coincidentPoints_option
Name Explanation
Specifies that defines how coincident data will be treated in Geostatistical Analyst.
  • MEAN—The mean of the data at the coincident location will be used. This is the default.
  • REMOVE_ALL—Coincident data will be excluded from the analysis.
  • MIN—The minimum value of the data at the coincident location will be used.
  • MAX—The maximum value of the data at the coincident location will be used.
  • INCLUDE_ALL—All the data will be used.
Scripting syntax
import arcpy
# Use the minimum value of the data at the coincident location.
arcpy.env.coincidentPoints = "MIN"
