Number of Retries on Failures (Environment setting)
Tools that honor the Number of Retries on Failures environment will retry the same worker process a specified number of attempts when there is a failure processing a particular job.
Usage notes
Occasionally, failures are encountered when running parallel raster analysis jobs.
For example, if the tool is running with a custom Python raster function code, failures can be caused by third-party Python code, such as memory errors when the worker process is processing a particular section of an image.
Having the worker process retry a particular section can recover analysis jobs.
Dialog syntax
Number of Retries on Failures—The number of retries that will be attempted when a worker process fails. The default is 0.
Python syntax
arcpy.env.retryOnFailures = retry_on_failures
| Name | Explanation |
retry_on_failures |
The number of times a worker process will be retried when there is failure processing a particular job. The default is 0. |
Scripting syntax
import arcpy
# Set the retry on failure to 3
arcpy.env.retryOnFailures = 3
