Parallel Processing Factor (Environment setting)
Tools that honor the Parallel Processing Factor environment will divide and perform operations across multiple processes.
Many modern computers include multicore CPUs. Spreading a geoprocessing operation across multiple processes can speed up performance by using more than one core. The performance benefit of parallel processing varies from tool to tool.
Usage notes
Individual tools may modify how this environment is used. See the tool documentation for any information that supersedes the information below.
  • The value of this environment determines the number of logical processes across which a tool spreads its operation. Those logical processes will be divided between hardware cores built into the machine. The number of hardware cores does not change based on this setting.
  • Each tool that honors this environment has a built-in default for the number of logical processes for a particular machine. You can change this based on your data, operation, and available resources.
  • If you specify a percent value (using the % symbol), the number of processes used will be the specified percentage of the number of cores on the machine, rounded to the nearest integer. For example, on a 4-core machine, setting 50% means the operation will be spread over 2 processes (50% * 4 = 2), setting 66% means the operation will be spread over 3 processes (66% * 4 = 2.64, which rounds to 3), and setting 100% means the operation will be spread over all 4 processes (100% * 4 = 4).
  • There are limitations when performing geoprocessing using an SQL Server Express database.
    SQL Server Express allows a maximum of three connections at a time. Each processing CPU requires a connection to the server. Additionally, the software running the tool, such as ArcGIS Desktop, counts as one connection process, leaving only two worker connection processes available for parallel processing.
  • Specifying more processes than your machine has cores may incur a performance penalty. This is because multiple processes will compete for resources on one core. To specify the environment in a way that avoids this competition, you can use either a percent value less than 100% or a number of processes less than the number of cores on your machine.
Dialog syntax
Parallel Processing Factor—The number of processes across which a tool will spread its operation.
  • blank (empty)—Each tool will determine how many processes to use. This is the default.
  • 0—Do not spread operations across multiple processes.
  • n—Use the specified number of processes. This value is limited to the number of processing units on the machine. If you specify a value greater than the number of cores available on your machine, the number of parallel processing instances will be limited to the number of cores available on your machine.
  • n%—Calculate the number of processes using the specified percentage: Number of processes = number of system cores * n / 100.
Python syntax
arcpy.env.parallelProcessingFactor = string
Name Explanation
string
  • Empty string (blank)—Let each tool determine how many processes to use. This is the default.
  • Do not spread operations across multiple processes.—Use the specified number of processes.
Scripting syntax
import arcpy
# Use half of the cores on the machine
arcpy.env.parallelProcessingFactor = "50%"
