Maintain fully qualified field names (Environment setting)
Tools that honor the Maintain fully qualified field names environment use this setting to distinguish between qualified and unqualified field names. Qualified field names are the names of fields in a feature class or table that have the name of the origin feature class or table appended to the field name. This setting is relevant when working with joined data.
Usage notes
  • The default qualified output table field naming structure is tableName.fieldName. When unqualified, the fields in the output table or feature class will always be named with the format fieldName.
  • In instances in which qualified field names may exceed the allowed field name width, set the environment to unqualified, for example, when joining shapefiles. Shapefile fields are truncated at eight characters.
  • When field mappings are included in a tool's parameters, as they are in many tools in the Conversion toolbox, field names are automatically unqualified, so it is not necessary to set this environment.
Dialog syntax
  • Checked—The output field name will include the table name. This is the default.
  • Unchecked—The output field name will not include the table name.
Python syntax
arcpy.env.qualifiedFieldNames = qualified_field_names
Name Explanation
  • True—The output field name will include the table name. This can also be set using the QUALIFIED keyword. This is the default.
  • False—The output field name will not include the table name. This can also be set using the UNQUALIFIED keyword.
Scripting syntax
# Name: addjoin.py
# Purpose: Join a table to a feature class and have the output unqualified
# Import system modules
import arcpy
# Set environment settings
arcpy.env.workspace = "C:/data"
arcpy.env.qualifiedFieldNames = False
# Set local variables
inFeatures = "Habitat_Analysis.gdb/vegtype"
layerName = "veg_layer"
joinTable = "vegtable.dbf"
joinField = "HOLLAND95"
expression = "vegtable.HABITAT = 1"
outFeature = "Habitat_Analysis.gdb/vegjoin"
# Create a feature layer from the vegtype feature class
arcpy.management.MakeFeatureLayer(inFeatures, layerName)
# Join the feature layer to a table
arcpy.management.AddJoin(layerName, joinField, joinTable, joinField)
# Copy the layer to a new permanent feature class
# Output fields are unqualified, so the field name will
# not contain the origin table
arcpy.management.CopyFeatures(layerName, outFeature)
