S-100 Feature Catalogue File (Environment setting)
Tools that honor the S-100 Feature Catalogue File environment use the specified file to map objects, attributes, feature classes, and relationships during data import and the creation of database schemas.
Usage notes
  • When using the tool dialog box, file paths are automatically generated using the S-100 feature catalogue file setting as follows:
    • If the S-100 Feature Catalogue File environment is set, the path will be automatically generated.
    • If the S-100 Feature Catalogue File environment is not set, you must set the input parameter for the feature catalogue file.
    • If the S-100 Feature Catalogue File environment is set, the file path that was automatically generated can be overwritten to supersede the environment.
Dialog syntax
S-100 Feature Catalogue File—The S-100 feature catalogue document that describes the content of a data product and specification.
Python syntax
arcpy.env.S100FeatureCatalogueFile = catalogue_file
Name Explanation
catalogue_file
Scripting syntax
import arcpy
# Set the S100FeatureCatalogueFile environment to local file
arcpy.env.S100FeatureCatalogueFile = 'C:/Program Files/ArcGIS/Pro/Resources/Maritime/S-101 ENCs_0.9.1.2.xml'
