Delete Polygon Fields From Locator (Geocoding Tools)
Summary
Deletes all polygon fields from a locator that were added using the Add Polygon Fields To Locator tool.
Usage
  • The Add Polygon Fields to Locator tool provides a workflow for appending custom attributes from polygons to local locators. This tool removes all custom output fields added from a polygon layer from an existing local locator.
  • The output of this tool can be used as the input locator to other tools in the Geocoding toolbox.
  • An ArcGIS StreetMap Premium license is required to delete polygon fields from ArcGIS StreetMap Premium locators.
Parameters
Label Explanation Data type
Input Locator
The locator (.loc file) containing the fields to be deleted.
Composite locators, locators published as a geocode service, and locators that do not contain a polygon layer are not supported.
Address Locator
Derived output
Updated Locator
The updated locator (.loc file) with the polygon output fields removed.
Address Locator
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
