Get Model Parameter (Geostatistical Analyst Tools)
Summary
Gets model parameter value from an existing geostatistical model source.
Usage
This tool is generally used in a model or in scripting.
The geostatistical model source must be a geostatistical layer.
See Set Model Parameter for additional information.
An example input model source:
/model[@name = 'Kriging']/model[@name = 'Variogram']/value[@name = 'Nugget']; /model[@name = 'Kriging']/model[@name = 'Variogram']/model[@name = 'VariogramModel']/value[@name = 'Range']will return "out_param_value" = 0.345;1127.14
The returned value can be viewed in the Geoprocessing History item for the run of this tool.
Parameters
| Label | Explanation | Data type |
Input geostatistical model source |
The geostatistical model source to be analyzed. |
File; Geostatistical Layer |
Parameter XML Path |
XML path to the required model parameter. |
String |
Derived output
Parameter value |
The model parameter value. |
String |
Environments
Licensing information
- Basic: Requires Geostatistical Analyst
- Standard: Requires Geostatistical Analyst
- Advanced: Requires Geostatistical Analyst
