Compute Confusion Matrix (Image Analyst Tools)
Summary
Computes a confusion matrix with errors of omission and commission and derives a kappa index of agreement, Intersection over Union (IoU), and overall accuracy between the classified map and the reference data.
This tool uses the outputs from the Create Accuracy Assessment Points tool or the Update Accuracy Assessment Points tool.
Usage
The accuracy assessment workflow usually uses the following three tools in this order: Create Accuracy Assessment Points, Update Accuracy Assessment Points, and Compute Confusion Matrix.
This tool computes a confusion matrix using the random accuracy assessment points. The accuracy assessment points are generated by the Create Accuracy Assessment Points tool and updated by the Update Accuracy Assessment Points tool. These two tools ensure that each point will have valid class values for the
ClassifiedandGrndTruthfields. These fields are both long integer field types. The tool calculates the user's accuracy and producer's accuracy for each class as well as an overall kappa index of agreement. These accuracy rates range from 0 to 1 in which 1 represents 100 percent accuracy. The following is an example of a confusion matrix:c_1
c_2
c_3
Total
U_Accuracy
Kappa
c_1
49
0.8594
c_2
0.9091
c_3
65
0.9077
Total
54
47
65
166
P_Accuracy
0.9074
0.8511
0.9077
Kappa
Confusion matrix example
User accuracy is a measure of the pixels that are correctly classified out of all the pixels that are classified as a given class. The remainder of the pixels classified into this class belong to a different class, or are identified as a different class, according to the reference information; they are false positives.
User accuracy is also referred to as errors of commission, or type 1 error. The data to compute this error rate is read from the rows of the table.
The Total row shows the number of points that should have been identified as a given class according to the reference data.
Producer accuracy is a false negative in which pixels of a known class are classified as something other than that class. An example is when the classified image identifies a pixel as forest, but it should be impervious. In this case, the impervious class is missing pixels according to the reference data.
Producer accuracy is also referred to as errors of omission, or type 2 error. The data to compute this error rate is read from the columns of the table.
The Total column shows the number of points that were identified as a given class according to the classified map.
Kappa index of agreement provides an overall assessment of the accuracy of the classification.
Intersection over Union (IoU) is the area of overlap between the predicted segmentation and the ground truth divided by the area of union between the predicted segmentation and the ground truth. The mean IoU value is computed for each class.
Parameters
| Label | Explanation | Data type |
Input Accuracy Assessment Points |
The accuracy assessment point feature class created from the Create Accuracy Assessment Points tool, containing the |
Feature Layer |
Output Confusion Matrix |
The output file name of the confusion matrix in table format. The format of the table is determined by the output location and path. By default, the output will be a geodatabase table. If the path is not in a geodatabase, specify the |
Table |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires Image Analyst or Spatial Analyst
- Standard: Requires Image Analyst or Spatial Analyst
- Advanced: Requires Image Analyst or Spatial Analyst
