Deep Learning Model To Ecd (Image Analyst Tools)
Summary
Converts a deep learning model to an Esri classifier definition file (.ecd).
Legacy:
This is a deprecated tool. This functionality has been replaced by the Export Training Data For Deep Learning tool that creates classification information for use in the deep learning model.
This tool adds missing class information to the model. Deep learning binary model files generated by Microsoft CNTK or similar applications are supported.
To utilize the deep learning .ecd file, the deep learning framework must be installed on your computer. The .ecd output file will only work as input to the Esri Python Classify or Detect adaptor function. The class information JSON file allows you to add useful information to the .ecd file not included in the deep learning binary model such as class names, class colors for rendering the classified output, and other standard information. See the JSON file example below for details.
Usage
The following is an example of a Input Esri Extra Info File:
This is an example of an
in_extra_info_jsonfile.{ "ImportDeepLearningModelToEsriExtraInfo":0, "Version":1, "Classifier":"CNTK", "NumberRasterBands":4, "MiniBatchSize":16, "Classes":[ { "Value":100, "Name":"Impervious", "Color":[204, 204, 204] }, { "Value":200, "Name":" Other (Pervious)", "Color":[56, 168, 0] } ] }
Parameters
| Label | Explanation | Data type |
Input Deep Learning Model File |
The binary model file generated by a deep learning package such as Microsoft CNTK or similar application. |
File |
Input Esri Extra Info File |
The class information JSON file. See the JSON file example above. |
File |
Output Classifier Definition File |
The The |
File |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires Image Analyst or Spatial Analyst
- Standard: Requires Image Analyst or Spatial Analyst
- Advanced: Requires Image Analyst or Spatial Analyst
