Create File Knowledge Graph (Knowledge Graph Tools)
Summary
Creates a file knowledge graph in a folder.
Usage
  • Use this tool to create a file knowledge graph. A knowledge graph allows you to create a model that simulates a real-world system in a nonspatial manner. Initially, the knowledge graph will be empty. However, using ArcGIS Pro, you can do the following:
    Learn more about ArcGIS Knowledge and creating knowledge graphs
  • The output path must already exist.
  • If the output file knowledge graph name does not include the .knowledgegraph extension, it will be added automatically.
Parameters
Label Explanation Data type
File Knowledge Graph Location
The folder where the file knowledge graph will be created.
Folder
File Knowledge Graph Name
The name of the file knowledge graph that will be created.
String
Document Entity Name
(Optional)
The name of the entity type in the data model that represents documents that are referenced by the knowledge graph. The default is Document.
String
Document Relationship Name
(Optional)
The name of the relationship type in the data model that represents a relationship between an entity in the knowledge graph and a document associated with that entity. The default is HasDocument.
String
Document Properties
(Optional)
The set of properties that will be created for each document entity.
Value table columns:
  • Text—The extracted text from a document. The default property name is text.
  • URL—The location of the document. The default property name is url.
  • Keywords—The keywords that will be used to search for the document. The default property name is keywords.
  • Name—The file name of the document. The default property name is name.
  • Content Type—The type of data contained by the referenced document. This property is stored as a Multipurpose Internet Mail Extensions (MIME) type. The default property name is contentType.
  • Title—The title of the document. The default property name is title.
  • Metadata—The metadata describing the document. The default property name is metadata.
  • File Extension—The file extension when the referenced document is a file. The default property name is fileExtension.
Value Table
Derived output
Output Knowledge Graph
The output file knowledge graph.
Workspace
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: No
  • Standard: No
  • Advanced: Yes
