Load Table To Knowledge Graph (Knowledge Graph Tools)
Summary
Loads data from a table or feature class into a knowledge graph.
Usage
Use this tool to create entities and relationships in a knowledge graph from existing tabular data. Data in a table's fields can be converted into properties of entities and relationships.
A data loading configuration file is required to load data into a knowledge graph. A data loading configuration file specifies how to read and handle the data in a table. It can also create provenance records to specify the source material from which the data was derived. Create a data load configuration file using the Load Table wizard.
When the Input Data parameter value is a feature class, identify the geometry field in the attribute table. When the Input Data parameter value is a table, identify one or more fields containing coordinates that define the entity's geometry. Only the WGS84 coordinate system is supported for knowledge graphs. It is assumed that all features and coordinates will use this coordinate system.
Parameters
| Label | Explanation | Data type |
Target Knowledge Graph |
The knowledge graph that will be updated. |
Workspace; String; Map; String; Knowledge Graph Layer |
Input Data |
The table or feature class that will be loaded into the knowledge graph. |
Table View |
Data Loading Configuration |
The data loading configuration file that will be used to load the Input Data parameter value into the knowledge graph. |
File |
Derived output
Updated Knowledge Graph |
The updated knowledge graph. |
Workspace |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Yes
- Standard: Yes
- Advanced: Yes
