Configure External Event Behaviors With LRS (Linear Referencing Tools)
Summary
Configures an external event in an LRS without connecting to an external event system.
Usage
  • The geodatabase where the external event is created and in which the LRS resides must be an enterprise geodatabase.
  • This tool can also be used to modify the name, geometry type, and event behaviors of the existing configured external events.
  • The following event behavior rules are set by default:
    Activity
    Rule
    Calibrate Route
    Stay Put
    Retire Route
    Stay Put
    Extend Route
    Stay Put
    Reassign Route
    Stay Put
    Realign Route
    Stay Put
    Reverse Route
    Stay Put
    Carto Realign Route
    Honor Route Measure
  • To update external events, provide required route and event information in the web service.
    Learn more about updating external events
Parameters
Label Explanation Data type
LRS Event Name
The name of the external event or table that will be registered to the LRS.
String
Parent LRS Network
The LRS Network to which the event will be registered.
Feature Layer
Geometry Type
(Optional)
Specifies the geometry type that will be used for the external event or table.
  • Point—The geometry type of the external event or table will be point. This is the default.
  • Line—The geometry type of the external event or table will be polyline.
String
Calibrate Rule
(Optional)
Specifies the event behavior rule that will be used for the calibrate activity.
  • Stay put—The geographic location of the event will be preserved, and measures may change. This is the default.
  • Retire—Both measure and geographic location will be preserved, and the event will be retired.
  • Move—The measures of the event will be preserved, and the geographic location may change.
String
Retire Rule
(Optional)
Specifies the event behavior rule that will be used for the retire activity.
  • Snap—The geographic location of the event will be preserved by snapping the event to a concurrent route, and measures may change.
String
Extend Rule
(Optional)
Specifies the event behavior rule that will be used for the extend activity.
  • Cover—The geometric location and measure of a line event will be modified to include a new or newly modified section.
String
Reassign Rule
(Optional)
Specifies the event behavior rule that will be used for the reassign activity.
String
Realign Rule
(Optional)
Specifies the event behavior rule that will be used for the realign activity.
String
Reverse Rule
(Optional)
Specifies the event behavior rule that will be used for the reverse activity.
String
Carto Realign Rule
(Optional)
Specifies the event behavior rule that will be used for the cartographic realign activity.
  • Honor Route Measure—The measure of the event will be preserved or changed proportionally to the route's measure change. This is the default.
String
Derived output
Updated LRS Workspace
The updated LRS workspace.
Workspace
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
