arcpy.lr.ConfigureExternalEventWithLRS(in_event, parent_network, event_name, event_id_field, route_id_field, measure_field, {geometry_type}, {to_measure_field}, {from_date_field}, {to_date_field}, {event_spans_routes}, {to_route_id_field}, {store_route_name}, {route_name_field}, {to_route_name_field}, {calibrate_rule}, {retire_rule}, {extend_rule}, {reassign_rule}, {realign_rule}, {reverse_rule}, {carto_realign_rule})
Name
Explanation
Data type
in_event
The external event feature class or table that will be registered to an LRS.
Table View
parent_network
The LRS Network to which the event will be registered.
Feature Layer
event_name
The name of the external event or table that will be registered to the LRS.
String
event_id_field
The event ID field available in the event feature class or table.
Field
route_id_field
The name of the route ID field if it is a point event or a line event that does not span routes, or the name of the from route ID field if the event spans routes. The field must be available in the external event table or feature class.
Field
measure_field
The name of the measure field if it is a point event or the name of the from measure field if it is a line event.
Field
geometry_type
(Optional)
Specifies the geometry type of the external event or table.
String
to_measure_field
(Optional)
The name of the to measure field. This field is only required for line events.
Field
from_date_field
(Optional)
The from date field in the event feature class or table.
Field
to_date_field
(Optional)
The to date field in the event feature class or table.
Field
event_spans_routes
(Optional)
Specifies whether the event records will span routes.
AS_IS—The property will not change. This is the default.
NO_SPANS_ROUTES—The event records will not span routes. This is applicable to line events only.
SPANS_ROUTES—The event records will span routes. This is applicable to line events only.
String
to_route_id_field
(Optional)
The name of the to route ID field available in the event feature class or table.
Field
store_route_name
(Optional)
Specifies whether the route name will be stored with the event records.
NO_STORE_ROUTE_NAME—The route name will not be stored with the event records.
STORE_ROUTE_NAME—The route name will be stored with the event records.
String
route_name_field
(Optional)
The route name field if it is a point event or line event that does not span routes, or the name of the from route name field if the event spans routes. The field must be available in the external event table or feature class.
Field
to_route_name_field
(Optional)
The to route name field for line events that span routes. This parameter is required if the store_route_name and event_spans_routes parameters are set.
Field
calibrate_rule
(Optional)
Specifies the event behavior rule for the calibrate activity.
STAY_PUT—The geographic location of the event will be preserved; measures may change. This is the default.
RETIRE—Both measure and geographic location will be preserved; the event will be retired.
MOVE—The measures of the event will be preserved; the geographic location may change.
String
retire_rule
(Optional)
Specifies the event behavior rule for the retire activity.
SNAP—The geographic location of the event will be preserved by snapping the event to a concurrent route; measures may change.
String
extend_rule
(Optional)
Specifies the event behavior rule for the extend activity.
COVER—The geometric location and measure of a line event will be modified to include a new or newly modified section.
String
reassign_rule
(Optional)
Specifies the event behavior rule for the reassign activity.
String
realign_rule
(Optional)
Specifies the event behavior rule for the realign activity.
String
reverse_rule
(Optional)
Specifies the event behavior rule for the reverse activity.
String
carto_realign_rule
(Optional)
Specifies the event behavior rule for the cartographic realign activity.
HONOR_ROUTE_MEASURE—The measure of the event will be preserved or changed proportionally to the route's measure change. This is the default.
String
Derived output
Name
Explanation
Data type
out_external_event_table
The updated external event table.
Table
Code sample
ConfigureExternalEventWithLRS example 1 (Python window)
The following script demonstrates how to use the ConfigureExternalEventWithLRS function to configure an external point event in the Python window.
# Name: Configure_Externalevent_LRS_ex1.py
# Description: Configure an external point event in an LRS Network in the Python window.
# Requires: ArcGIS Linear Referencing
# Tool variables
in_event = "C:\\Eventdata.sde\\pointevent"
parent_network = "C:\\Networkdata.sde\\Network1"
event_name = "PointEvent"
event_id_field = "EventId"
route_id_field = "RouteId"
measure_field = "Measure"
geometry_type = "POINT"
to_measure_field = None
from_date_field = "FromDate"
to_date_field = "ToDate"
event_spans_routes = "AS_IS"
to_route_id_field = None
store_route_name = "AS_IS"
route_name_field = None
to_route_name_field = None
calibrate_rule = "STAY_PUT"
retire_rule = "STAY_PUT"
extend_rule = "STAY_PUT"
reassign_rule = "STAY_PUT"
realign_rule = "STAY_PUT"
reverse_rule = "STAY_PUT"
carto_realign_rule = "HONOR_ROUTE_MEASURE"
# set current workspace
arcpy.env.workspace = "C:\\Networkdata.sde"
# run the tool
arcpy.lr.ConfigureExternalEventWithLRS(in_event, parent_network, event_name, event_id_field, route_id_field, measure_field, geometry_type, to_measure_field, from_date_field, to_date_field, event_spans_routes, to_route_id_field, store_route_name, route_name_field, to_route_name_field, calibrate_rule, retire_rule, extend_rule, reassign_rule, realign_rule, reverse_rule, carto_realign_rule)
ConfigureExternalEventWithLRS example 2 (Python window)
The following script demonstrates how to use the ConfigureExternalEventWithLRS function to configure an external line event in the Python window.
# Name: Configure_Externalevent_LRS_ex2.py
# Description: Configure an external line event in an LRS Network in the Python window.
# Tool variables
in_event = "C:\\Eventdata.sde\\lineevent"
event_name = "LineEvent"
measure_field = "FromMeasure"
geometry_type = "LINE"
to_measure_field = "ToMeasure"
store_route_name = "STORE ROUTE NAME"
route_name_field = "RouteName"
# Set current workspace
# Run the tool
ConfigureExternalEventWithLRS example 3 (Python window)
The following script demonstrates how to use the ConfigureExternalEventWithLRS function to modify an existing external line event in the Python window.
# Name: Configure_Externalevent_LRS_ex3.py
# Description: Modify an existing external line event in an LRS Network in the Python window. Event name and optional parameter fields are updated.
# Tool variables
event_name = "LineEvent_updated"
event_id_field = "EventId_updated"
route_id_field = "RouteId_updated"
measure_field = "FromMeasure_updated"
to_measure_field = "ToMeasure_updated"
from_date_field = "FromDate_updated"
to_date_field = "ToDate_updated"
store_route_name = "STORE_ROUTE_NAME"
route_name_field = "FromRouteName_updated"
calibrate_rule = "RETIRE"
retire_rule = "RETIRE"
extend_rule = "RETIRE"
reassign_rule = "RETIRE"
realign_rule = "RETIRE"
# Run the tool
ConfigureExternalEventWithLRS example 4 (stand-alone script)
The following stand-alone script demonstrates how to use the ConfigureExternalEventWithLRS function to configure an external line event spanning routes in an LRS Network.
# Name: Configure_Externalevent_LRS_ex4.py
# Description: Configure an external line event spanning routes in an LRS Network using a stand-alone Python script.
# Import arcpy module
import arcpy
# Tool variables
event_name = "LineSpanningEvent"
route_id_field = "FromRouteId"
event_spans_routes = "SPANS ROUTES"
to_route_id_field = "ToRouteId"
route_name_field = "FromRouteName"
to_route_name_field = "ToRouteName"
# Run the tool
ConfigureExternalEventWithLRS example 5 (stand-alone script)
The following stand-alone script demonstrates how to use the ConfigureExternalEventWithLRS function to modify an existing external line event spanning routes in an LRS Network.
# Name: Configure_Externalevent_LRS_ex5.py
# Description: Modify an existing external line event spanning routes of an LRS Network using a stand-alone Python script. Event name and optional parameter fields are updated.
import arcpy
# Tool variables
event_name = "LineSpanningEvent_updated"
route_id_field = "FromRouteId_updated"
to_route_id_field = "ToRouteId_updated"
to_route_name_field = "ToRouteName_updated"
# Run the tool
