Create LRS Event From Existing Dataset (Linear Referencing Tools)
Summary
Registers an existing feature class as an LRS event.
Usage
The event feature class must reside in a feature dataset that contains an LRS dataset.
The event feature class fields must include the properties specified in the LRS events data model.
The following event behavior rules are set by default:
Activity
Rule
Calibrate Route
Stay Put
Retire Route
Stay Put
Extend Route
Stay Put
Reassign Route
Stay Put
Realign Route
Stay Put
Carto Realign Route
Honor Route Measure
Parameters
| Label | Explanation | Data type |
Parent LRS Network |
The network to which the event will be registered. |
Feature Layer |
Event Feature Class |
The event to be registered. |
Feature Layer |
Event ID Field |
The event ID field in the event feature class. |
Field |
Route ID Field |
The route ID field if the feature class is a point event that doesn't span routes or the from route ID field if the feature class is a line event that spans routes. |
Field |
From Date Field |
The from date field in the event feature class. |
Field |
To Date Field |
The to date field in the event feature class. |
Field |
Loc Error Field |
The location error field in the event feature class. |
Field |
Measure Field |
The measure field if the feature class is a point event or the from measure field if the feature class is a line event. |
Field |
To Measure Field (Optional) |
The to measure field in the event feature class. This parameter is required for line events. |
Field |
Event Spans Routes (Optional) |
Specifies whether the event records will span routes.
Boolean |
To Route ID Field (Optional) |
The to route ID field for events that span routes. This parameter is required if the event feature class geometry type is polyline. |
Field |
Store Route Name (Optional) |
Specifies whether the route name will be stored with the event records.
Boolean |
Route Name Field (Optional) |
The route name field if the feature class is a point event that doesn't span routes or the from route name field if the feature class is a line event that spans routes. This parameter is required if Store Route Name is checked. |
Field |
To Route Name Field (Optional) |
The to route name field for line events that span routes. This parameter is required if Store Route Name is checked. |
Field |
Derived output
Output Event Feature Class |
The updated event feature layer. |
Feature Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires ArcGIS Linear Referencing
- Standard: Requires ArcGIS Linear Referencing
- Advanced: Requires ArcGIS Linear Referencing
