Create LRS Intersection From Existing Dataset (Linear Referencing Tools)
Summary
Registers an existing intersection feature class as an intersection.
Usage
  • The projected coordinate system of the intersecting feature classes must match that of the Parent LRS Network parameter value.
  • The Parent LRS Network parameter value can be used as an intersecting layer, so the intersections produced will be between the routes in a network.
  • The Parent LRS Network parameter value cannot be a feature service.
  • The Intersection Feature Class parameter value and the intersecting layers must be in the same geodatabase as the Parent LRS Network parameter value.
  • The name of the intersection is created by concatenating the Network Description Field parameter value with the Description Field value in the Intersecting Layers parameter, separated by the Name Separator value in the Intersecting Layers parameter.
  • The Intersection Feature Class fields must include the properties outlined in the LRS data model.
  • The intersecting layers must be z-enabled.
Parameters
Label Explanation Data type
Parent LRS Network
The network to which the intersection will be registered.
Feature Layer
The field in the network layer that will be used to name the intersections with other intersecting layers.
Field
The input point feature class to be registered.
Feature Layer
Intersection ID Field
The ID field in the Intersection Feature Class parameter value. The field must have a unique ID for each intersection for a time slice.
Field
Intersection Name Field
The field in the Intersection Feature Class parameter value that is a concatenated field showing the descriptors for the route and the intersecting feature.
Field
Route ID Field
The field in the Intersection Feature Class parameter value that contains the route ID for the LRS Network.
Field
Feature ID Field
The field in the Intersection Feature Class parameter value that contains the ID for the intersecting feature.
Field
Feature Class Name Field
The field in the Intersection Feature Class parameter value that contains the name of the feature class that participated in the intersection.
Field
From Date Field
The from date field in the Intersection Feature Class parameter value.
Field
To Date Field
The to date field in the Intersection Feature Class parameter value.
Field
Intersecting Layers
The feature class that intersects the LRS Network and contains the following information:
Value table columns:
  • Intersection Layer—The feature class that intersects the LRS Network.
  • ID Field—The field in the intersecting layer used to uniquely identify the feature that intersects the LRS Network.
  • Description Field—The field that provides the description, such as town or county name, of the intersecting feature.
  • Name Separator—The name separator for the intersection, such as AND, INTERSECT, +, or |.
Value Table
Consider z-values when generating intersections
(Optional)
Specifies whether z-values will be used when generating intersections.
  • Checked—Z-values will be used during generation of intersections.
  • Unchecked—Z-values will not be used during generation of intersections. This is the default.
Boolean
Z Tolerance
(Optional)
The z-tolerance used to generate intersections.
Double
Measure Field
(Optional)
The measure on the base route at the point of intersection.
Field
Derived output
Output Details File
The output feature class detailing the changes made to the Intersection Feature Class parameter value.
Feature Class
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
