Create LRS Intersection (Linear Referencing Tools)
Summary
Creates an intersection feature class for an existing LRS Network.
The output of this tool is an empty feature class with fields that conform to the LRS data model.
Run the Generate Intersections tool to generate intersection points after using this tool.
Usage
  • The projected coordinate system of the intersecting feature classes must match that of the Parent LRS Network parameter value.
  • The Parent LRS Network parameter value can be used as an intersecting layer, so the intersections produced will be between the routes in a network.
  • The Parent LRS Network parameter value cannot be a feature service.
  • The intersecting layers must be in the same geodatabase as the Parent LRS Network parameter value.
  • The name of the intersection is created by concatenating the Network Description Field parameter value with the Description Field value in the Intersecting Layers parameter, separated by the Name Separator value in the Intersecting Layers parameter.
  • The intersecting layers must be z-enabled.
  • Only a comma (,) is allowed as a name separator for route-on-route intersections.
Parameters
Label Explanation Data type
Parent LRS Network
The network to which the intersection will be registered.
Feature Layer
The field in the network layer that will be used to name the intersections with other intersecting layers.
Field
Intersection Feature Class
The name of the new intersection point feature class.
String
Intersecting Layers
The feature class that intersects the LRS Network and contains the following information:
Value table columns:
  • Intersection Layer—The feature class that intersects the LRS Network.
  • ID Field—The field in the intersecting layer used to uniquely identify the feature that intersects the network.
  • Description Field—The field that provides the description, such as town or county name, of the intersecting feature.
  • Name Separator—The name separator for the intersection, such as AND, INTERSECT, +, or |.
Value Table
Consider z-values when generating intersections
(Optional)
Specifies whether z-values will be used when generating intersections.
  • Checked—Z-values will be used when generating intersections.
  • Unchecked—Z-values will not be used when generating intersections. This is the default.
Boolean
Z Tolerance
(Optional)
The z-tolerance that will be used to generate intersections.
Double
Derived output
Output Feature Class
The registered output point feature class that will be m- and z-enabled. This feature class will be empty.
Feature Class
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
