Disable Derived Measure Fields (Linear Referencing Tools)
Summary
Disables fields that store the derived network route ID, route name, and measure fields.
This tool doesn't delete the derived measure fields; it only removes the derived measure fields' information from the Lrs_Metadata table.
Usage
  • You can use the tool on an empty event feature class or an event feature class that has loaded records.
Parameters
Label Explanation Data type
LRS Event Feature Class
An existing event feature class or feature layer that is registered to an LRS.
Feature Layer
Derived output
Updated Input Feature Class
The updated feature layer for the event.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
