Enable Referent Fields (Linear Referencing Tools)
Summary
Enables or modifies the referent fields so that you can manage referent information for the registered LRS event.
Usage
The tool enables the referent fields by allowing you to register the existing fields as the referent fields.
If referent fields are already enabled, the tool will populate the existing fields by default so that they can be modified.
The existing data in the referent fields is not validated or updated when you enable or modify the referent fields.
To disable the referent fields, use the Disable Referent Fields tool.
Parameters
| Label | Explanation | Data type |
Event Feature Class |
The feature class that will be used for the LRS event. |
Feature Layer |
Referent Method Field (Optional) |
The From referent method field. |
Field |
Referent Location Field (Optional) |
The From referent location field. |
Field |
Referent Offset Field (Optional) |
The From referent offset field. |
Field |
To Referent Method Field (Optional) |
The To referent method field. |
Field |
To Referent Location Field (Optional) |
The To referent location field. |
Field |
To Referent Offset Field (Optional) |
The To referent offset field. |
Field |
Offset Units (Optional) |
Specifies the offset unit of measure that will be used.
String |
Derived output
Output Event Feature Class |
The updated event feature layer. |
Feature Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires ArcGIS Linear Referencing
- Standard: Requires ArcGIS Linear Referencing
- Advanced: Requires ArcGIS Linear Referencing
