Enable Stationing Fields (Linear Referencing Tools)
Summary
Enables or modifies stationing fields so that you can manage stationing information for the registered LRS event.
Stationing is the fundamental system of measurement used for route layout and construction. Stations are reference points that are placed at a regular interval along the horizontal measurement of a route centerline. A starting reference station is established and all distances along the route centerline are measured from that station point.
Usage
Registering a stationing event layer allows you to locate stations with ahead and back station values at any measure along a route in an LRS Network.
Only one stationing event layer can be configured in an LRS Network.
If stationing fields are already configured, this tool will populate the existing fields so that they can be modified.
The Back Station Field parameter is automatically populated when an equation point is present at the station location.
The field values provided for the Decreasing Station Values parameter indicate that the station values decrease toward the direction of calibration of the route. If there is no value in the field, it means that the station values increase toward the direction of calibration of the route.
Parameters
| Label | Explanation | Data type |
Event Feature Class |
An existing event feature class or feature layer that is registered to an LRS. |
Feature Layer |
Station Field (Optional) |
The field that will be used as the starting reference station. |
Field |
Back Station Field (Optional) |
The field that will be used as the back station. |
Field |
Station Value Direction Field (Optional) |
The field that will be used to indicate the direction of increasing stations, either increasing toward the direction of calibration of the route or away from it. |
Field |
Station Measure Units (Optional) |
Specifies the unit of measure that will be used for stationing.
String |
Decreasing Station Values (Optional) |
A comma-separated list of user-provided values. |
String |
Derived output
Output Event Feature Class |
The updated feature layer for the event. |
Feature Layer |
Environments
This tool does not use any geoprocessing environments.
Licensing information
- Basic: Requires ArcGIS Linear Referencing
- Standard: Requires ArcGIS Linear Referencing
- Advanced: Requires ArcGIS Linear Referencing
