Generate Linear Referenced Length Summary (Linear Referencing Tools)
Summary
Creates a length data product for routes in an LRS Network without an LRS data template.
Usage
This tool supports data from a file geodatabase, an enterprise geodatabase (branch versioned connection), or a feature service (published from branch versioned data).
This tool does not modify the inputs and will create a
.csvfile or a geodatabase table as the output.The Effective Date parameter is used to define the temporal view of the network. Only routes active on this date will be used to calculate the output.
The summary layer must be a polygon feature class, an LRS line event feature class that is registered to the specified LRS Network, or an LRS Network.
The length layer must be an LRS Network or an LRS line event feature class that is registered to the specified LRS Network.
The summary and length layers must be stored in the same geodatabase or feature service and have the same coordinate system as the specified LRS Network.
A value of unclassified will be included in the output summary field for routes that do not overlap with the summary layers.
You can add multiple summary fields.
The output will be created based on the intersection of selected features from the LRS Network, summary layers, and length layers.
You can add multiple length fields from the same feature class by creating selection layers and specifying each selection layer as a length field. For example, if you have an LRS line event feature class, you can create two selection layers—Class A and Class B—and specify each selection layer as a length field.
Parameters
| Label | Explanation | Data type |
Input Route Features |
The route features that will be used to calculate the LRS length data product. |
Feature Layer |
Effective Date |
The date that will be used to define the temporal view of the network. The default value is today's date. |
Date |
Length Units |
Specifies the measure unit that will be used for the length fields in the output.
String |
Summary Fields (Optional) |
The fields from the layers that will be used to show the names for the summary rows in the output. Value table columns:
Value Table |
Length Fields (Optional) |
The fields from the layers that will be used to show the length of the routes in the output. Value table columns:
Value Table |
Exclude null summary rows (Optional) |
Specifies whether null summary rows will be excluded from the output.
Boolean |
Calculate length for dominant routes (Optional) |
Note:Support for this parameter will be added in a future release. |
Boolean |
Output Format (Optional) |
Specifies the format of the output.
String |
Output File (Optional) |
The output |
File |
Output Table (Optional) |
The output geodatabase table that will contain the length data product. |
Table |
Environments
Licensing information
- Basic: Requires ArcGIS Linear Referencing
- Standard: Requires ArcGIS Linear Referencing
- Advanced: Requires ArcGIS Linear Referencing
