Modify LRS Event (Linear Referencing Tools)
Summary
Modifies properties of a linear referencing system (LRS) event.
Usage
  • Modified fields should have the properties outlined in the LRS events data model.
  • This tool can be used to add or remove the following properties from an event:
    Present Event for a Continuous Network
    Event type
    Supports route name
    Supports spanning routes
    Line
    No
    N/A
    Line
    Yes
    N/A
    Point
    No
    N/A
    Point
    Yes
    N/A
    Modified Event for a Continuous Network
    Event type
    Supports route name
    Line
    Yes
    N/A
    Line
    No
    N/A
    Point
    Yes
    N/A
    Point
    No
    N/A
    Present Event for an Engineering Network
    Event type
    Supports route name
    Line
    No
    No
    Line
    Yes
    No
    Line
    Yes
    No
    Line
    Yes
    Yes
    Point
    No
    N/A
    Point
    Yes
    N/A
    Modified Event for an Engineering Network
    Event type
    Supports route name
    Line
    Yes
    No
    Line
    No
    No
    Line
    Yes
    Yes
    Line
    Yes
    No
    Point
    Yes
    N/A
    Point
    No
    N/A
Parameters
Label Explanation Data type
LRS Event Feature Class
The input feature class or feature layer for the event.
Feature Layer
Event ID Field
(Optional)
Name of the event ID field.
Field
Route ID Field
(Optional)
Name of the route ID field.
Field
From Date Field
(Optional)
Name of the from date field.
Field
To Date Field
(Optional)
Name of the to date field.
Field
Location Error Field
(Optional)
Name of the location error field.
Field
Measure Field
(Optional)
Name of the measure field if it is a point event or from measure field if it is a line event.
Field
To Measure Field
(Optional)
Name of the to measure field. Required only for line events.
Field
Event Spans Routes
(Optional)
Determines if the event records will span routes.
  • As is—No change to the property. This is the default.
  • Do not span routes—The event records do not span routes. Applicable only for line events.
  • Spans routes—The event records may span routes. Applicable only for line events.
String
To Route ID Field
(Optional)
Name of the to route ID field. Required only if it is a line event and it spans routes.
Field
Store Route Name
(Optional)
Determines if the event records will store the route name.
  • Store route name—Stores the route name with the event records.
  • Do not store route name—Does not store the route name with the event records.
String
Route Name Field
(Optional)
The route name field if it is a point event that does not span routes, or the from route name field if it is a line event that spans routes. Required if Store Route Name is enabled.
Field
To Route Name Field
(Optional)
Name of the to route name field. Required if it is a line event, Store Route Name is chosen, and it spans routes.
Field
Derived output
Updated LRS Event Feature Class
The updated event feature layer.
Feature Layer
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
