Modify LRS Intersection (Linear Referencing Tools)
Summary
Modifies the properties of an intersection feature class, such as fields and intersecting layers, that compose the intersection feature class and can be added or removed.
Usage
  • The input Intersection Feature Class parameter value should be a feature layer and cannot be a service layer.
  • This tool can be used on a feature class without geometry or records.
  • The spatial reference, tolerance, and resolution of the Intersection Feature Class and Intersecting Layers parameter values must match.
  • The Intersection Feature Class and Intersecting Layers parameter values must be in the same workspace.
  • Feature classes provided as Intersecting Layers must be z-enabled.
  • The sum of Intersecting Layers field lengths must be less than or equal to the Intersection Name Field length.
  • The Intersection Feature Class must have the following fields configured:
    Field
    Data type
    Character length
    Nullable
    IntersectionId
    Field (Guid)
    38
    No
    An automatically generated field providing a unique ID for each intersection.
    IntersectionName
    String
    1000
    Yes
    A concatenated field showing the descriptors for the route and intersecting feature.
    RouteId
    String
    1000
    No
    The route ID of the route network.
    FeatureId
    String
    1000
    Yes
    The ID of the intersecting feature.
    FeatureClassName
    String
    150
    No
    The name of the feature class that participated in the intersection.
    FromDate
    Date
    NA
    Yes
    The From Date of the route.
    ToDate
    Date
    NA
    Yes
    The To Date of the route.
    Measure
    Double
    NA
    Yes
    The measure on the base route at the point of intersection.
Parameters
Label Explanation Data type
The input LRS intersection feature layer. This feature class cannot be a service.
Feature Layer
Intersection ID Field
(Optional)
The field in the Intersection Feature Class to use as the intersection unique ID field.
Field
(Optional)
The concatenated field in the Intersection Feature Class that contains the descriptors for the route and the intersecting feature.
Field
Route ID Field
(Optional)
The field in the Intersection Feature Class that contains the unique route ID.
Field
Feature ID Field
(Optional)
The field in the Intersection Feature Class that contains the ID of the intersecting feature.
Field
Feature Class Name Field
(Optional)
The field in the Intersection Feature Class that contains the name of the feature class that participated in the intersection.
Field
From Date Field
(Optional)
The field in the Intersection Feature Class that contains the from date of the route.
Field
To Date Field
(Optional)
The field in the Intersection Feature Class that contains the to date of the route.
Field
Intersecting Layers
(Optional)
The Intersection Feature Class fields that compose the intersecting layer.
Value table columns:
  • Intersection Layer—The feature class that intersects the LRS Network.
  • ID Field—The field in the intersecting layer used to uniquely identify the feature that intersects the network.
  • Description Field—The field that provides the description, such as town or county name, of the intersecting feature.
  • Name Separator—The name separator for the intersection, such as AND, INTERSECT, +, or |.
Value Table
Measure Field
(Optional)
The field in the Intersection Feature Class that contains the measure on the base route at the point of intersection.
Field
Derived output
Output Details File
The updated Intersection Feature Class.
Feature Class
Environments
This tool does not use any geoprocessing environments.
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
