Modify LRS (Linear Referencing Tools)
Summary
Modifies an existing linear referencing system (LRS) in the specified workspace.
Usage
  • This tool can be used on a feature class or table with or without geometry or records.
  • The route ID and centerline ID must be unique; however, the tool does not check for duplicate IDs.
  • This tool does not check for erroneous network IDs; if the network ID does not exist, it is considered erroneous.
    Learn more about configuring LRS and field properties in the LRS data model
  • The Realign Overlaps rule for event behavior supported in ArcMap is not supported in ArcGIS Pro.
    If event behaviors were configured in ArcMap using the Realign Overlaps rule, substitutions will be made using comparable Realign event behavior values.
    This tool will check for conflicting Realign and Realign Overlaps event behaviors and will support Realign event behavior if Realign Overlaps event behavior is encountered. This tool does not support Realign Overlaps event behavior.
    The Snap option supported in ArcMap is supported for Realign event behavior in ArcGIS Pro 2.9 or later.
    The following table lists the resulting value in ArcGIS Pro for configured Realign and Realign Overlaps event behavior in an LRS migrated from ArcMap:
    If Realign in ArcMap is
    And Realign Overlaps in ArcMap is
    Realign in ArcGIS Pro will be
    Stay Put
    Move
    Stay Put
    Stay Put
    Retire
    Stay Put
    Stay Put
    Cover
    Stay Put
    Stay Put
    Snap
    Snap
    Move
    Stay Put
    Move
    Move
    Retire
    Move
    Move
    Cover
    Move
    Move
    Snap
    Snap
    Retire
    Stay Put
    Retire
    Retire
    Move
    Retire
    Retire
    Cover
    Retire
    Retire
    Snap
    Snap
    Cover
    Stay Put
    Cover
    Cover
    Move
    Cover
    Cover
    Retire
    Cover
    Cover
    Snap
    Cover
Parameters
Label Explanation Data type
Input Workspace
The LRS workspace.
Workspace
Current LRS Name
The name of the current LRS.
String
New LRS Name
(Optional)
The new name of the current LRS.
String
Centerline - Feature Class
(Optional)
An existing centerline feature class for the minimum schema.
Feature Layer
Centerline - Centerline ID Field
(Optional)
The name of the centerline ID field from the Centerline - Feature Class parameter value.
Field
Centerline Sequence - Table
(Optional)
An existing centerline sequence table for the minimum schema.
Table View
Centerline Sequence - Centerline ID Field
(Optional)
The name of the centerline ID field from the Centerline Sequence - Table parameter value.
Field
Centerline Sequence - Route ID Field
(Optional)
The name of the route ID field from the Centerline Sequence - Table parameter value.
Field
Centerline Sequence - From Date Field
(Optional)
The name of the from date field from the Centerline Sequence - Table parameter value.
Field
Centerline Sequence - To Date Field
(Optional)
The name of the to date field from the Centerline Sequence - Table parameter value.
Field
Centerline Sequence - Network ID Field
(Optional)
The name of the network ID field from the Centerline Sequence - Table parameter value.
Field
Calibration Point - Feature Class
(Optional)
An existing calibration point feature class for the minimum schema.
Feature Layer
Calibration Point - Measure Field
(Optional)
The name of the measure field from the Calibration Point - Feature Class parameter value.
Field
Calibration Point - From Date Field
(Optional)
The name of the from date field from the Calibration Point - Feature Class parameter value.
Field
Calibration Point - To Date Field
(Optional)
The name of the to date field from the Calibration Point - Feature Class parameter value.
Field
Calibration Point - Route ID Field
(Optional)
The name of the route ID field from the Calibration Point - Feature Class parameter value.
Field
Calibration Point - Network ID Field
(Optional)
The name of the network ID field from the Calibration Point - Feature Class parameter value.
Field
Redline - Feature Class
(Optional)
An existing redline feature class for the minimum schema.
Feature Layer
Redline - From Measure Field
(Optional)
The name of the from measure field from the Redline - Feature Class parameter value.
Field
Redline - To Measure Field
(Optional)
The name of the to measure field from the Redline - Feature Class parameter value.
Field
Redline - Route ID Field
(Optional)
The name of the route ID field from the Redline - Feature Class parameter value.
Field
Redline - Route Name Field
(Optional)
The name of the route name field from the Redline - Feature Class parameter value.
Field
Redline - Effective Date Field
(Optional)
The name of the effective date field from the Redline - Feature Class parameter value.
Field
Redline - Activity Type Field
(Optional)
The name of the activity type field from the Redline - Feature Class parameter value.
Field
Redline - Network ID Field
(Optional)
The name of the network ID field from the Redline - Feature Class parameter value.
Field
Conflict Prevention
(Optional)
Specifies whether conflict prevention will be enabled for the input LRS. Conflict prevention is only available when editing or performing geoprocessing on branch versioned data that is published as a feature service.
  • As is—The current conflict prevention setting will be used. This is the default.
  • Enable—Conflict prevention will be enabled for the input LRS.
  • Disable—Conflict prevention will be disabled for the input LRS.
String
Move required feature classes to feature dataset
(Optional)
Specifies whether feature classes will be moved to the required LRS feature dataset.
  • Checked—Feature classes will be moved to the required LRS feature dataset.
  • Unchecked—Feature classes will not be moved to the required LRS feature dataset. This is the default.
Boolean
Derived output
Updated Input Workspace
The updated LRS workspace string.
Workspace
Environments
Current Workspace
Licensing information
  • Basic: Requires ArcGIS Linear Referencing
  • Standard: Requires ArcGIS Linear Referencing
  • Advanced: Requires ArcGIS Linear Referencing
