Overlay Route Events (Linear Referencing Tools)
Summary
Overlays two event tables to create an output event table that represents the union or intersection of the input.
Usage
  • Line-on-line, line-on-point, point-on-line, and point-on-point event overlays can be performed.
  • The input and overlay events should be based on the same route reference.
  • The input tables can be any type of table that ArcGIS supports. The output table can be a .dbf file or a geodatabase table.
  • The Output Event Table parameter value can be displayed in a map using the Make Route Event Layer tool.
  • If both the input and overlay event properties are type Point, the output event properties must also be defined as type Point.
  • If both the input and overlay event properties are type Line, the output event properties must also be defined as type Line.
  • If either the input or overlay event properties are type Point, the output event properties must be defined as type Point when the Type of Overlay parameter value is Intersect. The output event properties must be defined as type Line when the Type of Overlay parameter value is Union.
  • If both the input and overlay event properties are type Point, only the points that have the exact same measure value are considered to intersect. There is no search tolerance.
  • An attribute index on the route identifier field speeds up the dynamic segmentation process. If you will be using the Output Event Table parameter value for dynamic segmentation, it is recommended that you create an attribute index.
  • Use the Make Table View tool before running this tool to reduce the number of events that will be processed.
  • If either the input or overlay events do not have an ObjectID field, use the Make Query Table tool before running this tool to add a virtual ObjectID field.
Parameters
Label Explanation Data type
Input Event Table
The input event table.
Table View
Input Event Table Properties
The route location fields and the type of events in the input event table.
  • Route Identifier Field—The field containing values that indicate the route on which each event is located. This field can be a numeric, text, or GUID field.
  • Event Type—The type of events in the input event table (Point or Line).
    • Point—Point events occur at a precise location along a route. Only a from-measure field must be specified.
    • Line—Line events define a portion of a route. Both from- and to-measure fields must be specified.
  • From-Measure Field—A field containing measure values. This field must be numeric and is required when the event type is Point or Line. When the Event Type value is Point, the label for this parameter becomes Measure Field.
  • To-Measure Field—A field containing measure values. This field must be numeric and is required when the event type is Line.
Route Measure Event Properties
Overlay Event Table
The overlay event table.
Table View
Overlay Event Table Properties
The route location fields and the type of events in the overlay event table.
Route Identifier Field—The field containing values that indicate which route each event is along. This field can be a numeric, text, or GUID field.
Event Type—The type of events in the overlay event table (Point or Line).
From-Measure Field—A field containing from-measure values. This field must be numeric and is required when the event type is Point or Line. When Event Type is Point, the label for this parameter becomes Measure Field.
To-Measure Field—A field containing to-measure values. This field must be numeric and is required when the event type is Line.
Type of Overlay
Specifies the type of overlay that will be performed.
  • Intersect—Only overlapping events will be written to the output event table. This is the default.
  • Union—All events will be written to the output table. Linear events will be split at their intersections.
String
Output Event Table
The table that will be created.
Table
Output Event Table Properties
The route location fields and the type of events that will be written to the output event table.
  • Route Identifier Field—The field that will contain values that indicate the route on which each event is located. The field can be a numeric, text, or GUID field.
  • Event Type—The type of events the output event table will contain (Point or Line).
    • Point—Point events occur at a precise location along a route. Only a single measure field must be specified.
  • From-Measure Field—A field that will contain measure values. This field is required when the event type is Point or Line. When the Event Type value is Point, the label for this parameter becomes Measure Field.
  • To-Measure Field—A field that will contain measure values. This field is required when the event type is Line.
Keep zero length line events
(Optional)
Specifies whether zero-length line events will be added to the Output Event Table parameter value. This parameter is only valid when the output event type is Line.
  • Checked—Zero-length line events will be added. This is the default.
  • Unchecked—Zero-length line events will not be added.
Boolean
Include all fields from input
(Optional)
Specifies whether all the fields from the input and overlay event tables will be included in the Output Event Table parameter value.
  • Checked—All the fields from the input tables will be included in the output table. This is the default.
  • Unchecked—All the fields from the input tables will not be included in the output table. Only the ObjectID field and the route location fields will be included.
Boolean
Build index
(Optional)
Specifies whether an attribute index will be created for the route identifier field that is written to the Output Event Table parameter value.
  • Checked—An attribute index will be created. This is the default.
  • Unchecked—An attribute index will not be created.
Boolean
Environments
Current Workspace, Output CONFIG Keyword, Scratch Workspace
Licensing information
  • Basic: Yes
  • Standard: Yes
  • Advanced: Yes
